Breaking up around 4-6k
Old Dec 4, 2010 | 08:51 AM
550whpcivic's Avatar
Default Breaking up around 4-6k
first gear pulls good second pull very good and third it back fires and feels like boost cut but my data-logs don't show it. Boost cut is at 12.0 psi and datalog show 9.6psi
Fully built b16 60 trim 440cc injectors
hondata s300
Old Dec 4, 2010 | 08:08 PM
mtber's Avatar
Default Re: Breaking up around 4-6k
Do you have a wideband oxygen sensor gauge installed on the vehicle?
If so, what are the air fuel ratios at during full throttle 3rd gear full boost?
If not, get one before proceeding.
Old Dec 5, 2010 | 07:52 AM
93turbo16's Avatar
hondata s300
See above and in addition, check your plug gap.
Old Dec 13, 2010 | 05:05 PM
SH4DY's Avatar
What's the duty cycle on the injectors?
What do your timing tables look like?
and as mentioned above: AFR's and plug gap...
b16bri
Jan 26, 2012 01:51 PM
93supercoupe
Sep 17, 2011 03:49 PM
93supercoupe
Sep 17, 2011 01:41 PM
418whpturboD
Jan 4, 2009 03:30 PM
DriveSlowHomie
Sep 27, 2005 05:54 AM
