Need advice on crome map.
Old Oct 10, 2013 | 10:47 PM
aavtec's Avatar
Default Need advice on crome map.
Engine: B18C1, 81.5mm USDM ITR pistons, ebay intake manifold, test pipe.
Chipped obd1 p72
Motor has 5300 miles on build. First 3k were done on a obd2 p72 (no money, needed my car)
Currently running a 13.5 AFR street tune my buddy and I made for his lsv (b16 head, pistons) which cracked all his ring-lands. He decided to advance his dizzy at thunder-hill and car was having massive blow-by from the pcv box by 2nd session. Surprised he did 3 total sessions with a catch can. Car was dumping 1qt a session but still had power.
Anyway my dizzy is set at +14 at idle with the blown up map, don't no the AFR. my buddy made some adjustments to the map. I have it burnt but not installed.
Need input on maps.
File Type: zip
Old Oct 11, 2013 | 08:47 AM
AaronEJ's Avatar
Default Re: Need advice on crome map.
wanted to take a look
but the zip file isnt working.
sent you a pm
Old Oct 12, 2013 | 07:43 AM
halfakneegrow's Avatar
Get a stock itr map then get it tuned
Old Oct 12, 2013 | 08:54 PM
njw202's Avatar
Looking for a good basemap for h2b
Old Oct 14, 2013 | 02:29 PM
aavtec's Avatar
sent you a pm
Replied and thank you.
Also re-uploaded the crome maps.zip, should be working fine now.
File Type: zip
Old Oct 15, 2013 | 06:27 PM
VegasInvasion's Avatar
I'm Huge In Japan
^This runs like garbage on this setup, but it's safe.
There's a solid 5-8* ignition buffer on the stock rom over a tuned GSR, so the stock P72 map works great if you add about 5-10% fuel in higher load just to be safe.
...Obviously tune it, but you get the idea.
cxserver
Engine Management and Tuning
Oct 17, 2010 11:39 PM
b20turbocivic
14
Dec 28, 2009 11:31 AM
Linus_E
Mar 29, 2005 09:07 AM
rice4life
12
Jan 5, 2005 05:27 PM
DocSean
Dec 9, 2004 04:37 AM
