Neptune - mapping
Old Oct 19, 2013 | 09:49 PM
ram1211's Avatar
Default Neptune - mapping
Hello guys,
Last night while mapping a b18c4 swapped EK with b16b cams, we got a major issue. While getting into vtec point mapped at 5400 rpm or even as it was before, the car will knock and air/fuel will show 10.0 and below I suppose. but just after that its fine. If I slowly hold it on the 5400 rpm Vtec point, the car will start shaking and knock as air/fuel will show 10.0. And also, the air fuel will go down to 10.0 each time he shifts gear.
Issue is that there is a power loss point when vtec getting in, it got a walbro fuel pump. But apart from that issue, the car runs good.
Any ideas guys? Thanks a lot.
Old Oct 20, 2013 | 11:13 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: Neptune - mapping
the power loss is probably because it has too much ignition advance and is trying to turn in the opposite direction. also that's what knock is. start with a P73 base and retard ignition, then tune it.
Old Oct 20, 2013 | 11:49 PM
ram1211's Avatar
thanks will check it and revert back
PierceBLewis
Sep 2, 2017 10:35 AM
eastbayg
Aug 25, 2008 09:49 AM
turboH22Aakkord
Oct 8, 2005 05:15 AM
97LudeSH
Sep 5, 2001 01:23 PM
