apex vtec controler help
Old Oct 25, 2013 | 02:34 PM
Smokey27's Avatar
Icon2 apex vtec controler help
hey guys I have a ls/vtec with a dc header cold air intake stage 2 blox cams and a bigger intake. im having a problem after i installed my cams my car began to flood from 5-6 rpms and as soon as it hits 6 when vtec kicks in it starts to clear up i have a mechanic that usally does all the tunning but he cant get to my car quick enough can anyone help me figur out how to fix this problem i also have a wideband axygen sensor with gauge so i can see my fuel ratings
Old Oct 25, 2013 | 07:56 PM
F22Master's Avatar
Default Re: apex vtec controler help
... pull fuel to keep AFR @12.5-13:1. Am I missing something?
Although you should be running LEAN with bigger cams, not rich.
Old Oct 26, 2013 | 02:14 AM
Smokey27's Avatar
my afr is jumping to the 17s im not sure how to turn it down with the controller i had a guy that done all my tunning and now im lost on how to use the vtec controller is there a way that i can just adjust that rpm range ?
Old Oct 26, 2013 | 07:12 AM
F22Master's Avatar
I would recommend getting a chipped ECU. Get rid of that crap and just program the chip properly.
Old Oct 26, 2013 | 12:26 PM
Smokey27's Avatar
What kind do u recommended ?? I wish I understood more on the tunning there's none around here that goes that deep into building
Old Oct 28, 2013 | 08:53 AM
spAdam's Avatar
Loved
Community Favorite
Tuning, not tunning.
What ecu are you running? What is your wideband setup? we need more info. Also, as F22Master said, ditching the VAFC and going with something more modern should most likely be your next step. Those things have been irrelevant for at least ten years.
Old Oct 28, 2013 | 09:25 AM
Spunkster's Avatar
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html). I would recommend the s300.
liljukmoves
10
Jun 29, 2011 07:59 PM
RiSiNgDc2
Mar 11, 2006 09:08 PM
ALLMOTOR00SI
Sep 12, 2005 09:27 AM
12secLSvtec
11
May 20, 2004 12:04 PM
teg1.6
Sep 13, 2001 06:27 PM
