Aem stat sync issue?
Old Nov 2, 2013 | 01:36 PM
siblues's Avatar
Default Aem stat sync issue?
I just wanted to see if any of you guys could chime in and maybe help me out.I first would like to point out that I know nothing about tuning.I am just trying to save a little cash and diagnosing the problem if possible.I am running a 30-1050 box with a twinfire running a cop setup and T1 cam trigger on a boosted b16.I have checked everything I can think of and even sent the ems and twinfire in to aem to make sure they were ok.The T1 hall effect sensor is ok and the mechanical side is all working properly.I just cant seem to get the stat sync to turn on.The wiring in the car is all Rywire stuff and it has been checked that isnt the problem can anyone chime in and maybe offer something I missed or maybe something that can cause this issue.The car turns over fine it just doesnt start and the stat synce never comes on.Thanks
Old Nov 24, 2013 | 04:22 AM
siblues's Avatar
Default Re: Aem stat sync issue?
Well I am keeping my fingers crossed to see if anyone is willing to try to help a fellow member out.Thanks
Old Nov 25, 2013 | 08:01 AM
Rtype16's Avatar
can you post a link to your calibration?
Old Nov 25, 2013 | 07:42 PM
a1320addict's Avatar
Have you moved both JPT1 and JPT2 as needed for Hall Effect?
What is the airgap on the trigger?
Old Nov 26, 2013 | 08:58 AM
Rtype16's Avatar
AS stated above have you moved the jumpers for your configuration? Have you changed the calibration so it reflects what you are using?
Old Nov 27, 2013 | 09:49 AM
siblues's Avatar
Jumpers have been moved and the sensor is gapped to the T1 specs.Those are the first two things I tried.The thing thats driving me nuts is that the car was running and now its not.I had someone work on the car and after they touched it the stat sync doesnt turn on.They didnt touch the cal but something happened.I cant count on them to solve this either.
Here is the cal
http://www64.zippyshare.com/v/88293682/file.html
Old Nov 27, 2013 | 01:02 PM
Rtype16's Avatar
Open your calibration up. Navigate to Setup -> Sensors -> Cam/Crank Sensor -> Advanced Cam/Crank -> Template(Top)
Try this first
Under Options for Mag Pickup.
Set Crank H Sens Below to 0
Set Crank L Sens Above to 0
Set Cam High Sens Below to 0
Set Cam Low Sens Above to 0
Try this if it still doesn't work.
Set Crank Rising Edge to on
Set Cam Rising Edge to on
Turn off Crank Falling Edge
Turn off Cam Falling Edge
Make sure to get a timing light and check timing again.
Also someone touched the cal because it would not run with some of those settings changed with a T1 trigger.
Old Nov 28, 2013 | 04:21 AM
siblues's Avatar
I will try that out.I have a few more cals that may be the original before it was changed.I am really surprised that someone changed it without my knowledge.
Old Nov 29, 2013 | 11:56 AM
Where are you located?
Old Nov 29, 2013 | 12:12 PM
siblues's Avatar
Pm'd
I tried what you said Rtype and no luck and I still cant get stat sync to turn on.
Old Dec 2, 2013 | 07:45 AM
Rtype16's Avatar
Contact aem tech support at emstech@aempower.com
hyabusa hunter
Jan 3, 2007 12:12 PM
allmotorsi04
Mar 20, 2006 03:28 PM
sportridermike
Honda S2000
May 26, 2005 02:56 PM
yellowturbo
Mar 29, 2005 09:17 AM
