Hondata S300 Boost control problem
Old Aug 23, 2013 | 12:40 AM
the_racerx's Avatar
Default Hondata S300 Boost control problem
Hi,
I have the S300 system with Boost control and Aem/Mac Solenoid.
I want to drive 18 psi but it doesnt work. The wastegate open at oem pressure spring (10psi).
Here is my Boost control setup
Uploaded with ImageShack.us
I played with the duty cycle and gear based target boost but nothing helped.
When i switch on the ignition, the solonoid make a "clack". So can be sure that s300 and the solenoid works.
Old Aug 23, 2013 | 08:06 AM
Muckman's Avatar
Moderator in Chief
Default Re: Hondata S300 Boost control problem
When you adjust the % fixed duty cycle does the solenoid change the buzzing sound it makes? If it does then that confirms the Ecu is properly driving the solenoid and the problem is likely how its plumbed.
Old Aug 23, 2013 | 08:55 AM
Spunkster's Avatar
Is it a normally open or closed solenoid? If it is closed and you have it set to open and a duty cycle of 90% then you effectively are using a duty cycle of 10%.
Has the ECU been properly prepared with the components for boost control to work?
http://www.hondata.com/help/smanager...=boost+control
rudebwoy
Jun 5, 2018 06:30 PM
Listerofsmeg
Feb 10, 2012 05:16 AM
sikasscivic
May 18, 2011 04:18 PM
imationdawg
Jul 22, 2009 05:24 PM
.adam.
Engine Management and Tuning
15
Aug 11, 2008 10:44 PM
