setting up a base tune
Old Oct 26, 2013 | 08:02 AM
9honda5civic's Avatar
Default setting up a base tune
Can anybody give me any advise on running a base tune to break in my b16a its 11.5-1 cr and has jdm type r head and valve train I know I'm suppose to take it to get it professionally tuned but I'd like to break it in before they beat it up on a dyno can I just simply run a stock tune or do I need more than that thanks for any help
Old Oct 26, 2013 | 08:03 AM
Sorry I forgot to put I have hondata s300
Old Oct 26, 2013 | 09:01 AM
motoxxxman's Avatar
Default Re: setting up a base tune
look through the maps available through the smanager software, you may find one with a very similar setup. just make sure to set your injector size, and run in closed loop with an active o2 sensor to ensure af's are decent during normal driving, and proper fuel trims get set for higher throttle.
or you can just ask your tuner to make you a basemap
Old Oct 26, 2013 | 09:13 AM
I'd like to be able to ask my tuner but at the moment I don't have one because I live in the middle of wisconsin and the closest shop is at least 2 hours away haha
Old Nov 4, 2013 | 04:17 PM
VegasInvasion's Avatar
I'm Huge In Japan
they can still email you one. or you can buy one on Xenocron.com or any number of members on here.
Old Nov 5, 2013 | 05:26 PM
98vtec's Avatar
moderator emeritus
how about you take it to your tuner and have them break the engine in properly?
Old Nov 5, 2013 | 09:51 PM
mtber's Avatar
A basemap file or e-tune would be your best bet:
http://www.phearable.net/shoppingcar...ware-c-40.html
I highly recommend getting a wideband before starting a fresh motor, even on a basemap.
kraquepype
Engine Management and Tuning
Nov 16, 2018 09:30 PM
Frstyl838
Sep 28, 2007 09:54 AM
88ED8
Dec 23, 2006 11:50 AM
Short_Shifter
Mar 27, 2002 06:18 AM
veejay
Aug 14, 2001 12:58 AM
