Mini me
Old Nov 9, 2013 | 05:09 PM
Douglasjdm's Avatar
Default Mini me
Hey guys I got a question for y'all I bought a d-series vtec head because I am doing a mini mi swap and my block is the d15b7 so I'm wondering. How can you tell if the head is z6 or y8 ? Let me know because I am confused I really need to know
Old Nov 9, 2013 | 08:19 PM
nub's Avatar
nub
Default Re: Mini me
Easy visual is combustion chamber design. Don't care to explaine so eaier is to look at the casting number on the exhaust side of the head.
P08 = Z6
P2J = Y8
Old Nov 11, 2013 | 03:27 PM
Ej1coupe3's Avatar
Default Re: Mini me
P08 = Z6
P2J = Y8
What he said on the very back of the intake theres a P08 for z6 and P2J for Y8 did you do the mini me or did you buy it like that
Old Nov 17, 2013 | 01:18 PM
Douglasjdm's Avatar
I did the mini me and now I'm wondering why my car won't start?? What did I do wrong? It cranks but it won't start. It just won't turn over.
Old Nov 20, 2013 | 12:36 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: Mini me
most likely your timing belt is off a tooth, I see that a lot. otherwise you probably just have some wires mixed up, so check the codes and do general troubleshooting steps in your haynes manual. if you don't have one, you posted here prematurely.
Old Nov 20, 2013 | 06:08 PM
nub's Avatar
nub
Default Re: Mini me
Being a tooth off wont keep from starting. Would it run as well as it could? No.
He has something else going on. It could still be mechanical timing but one tooth off is't it.
Using a 1.5 block with a Z6 or Y8 head requires a mix of parts due to the dfference in deck height of the 1.5 and 1.6. There's also a difference in cam keyway indexing on the Z6 and Y series relative to TDC that has to be accounted for. What the actual combo of block, head and cam determines the cam gear and mechanical timing method used, Z6 vs Y.
Old Nov 21, 2013 | 07:37 AM
AaronEJ's Avatar
Default Re: Mini me
which ECU did you use, if you have used a obd2 ECU
i bet its the immobilizer
if you have used a obd1, check if you are getting spark and fuel.
Old Nov 22, 2013 | 03:36 PM
I'm Huge In Japan
Default Re: Mini me
It won't start if you're a tooth off on a mini-me or a shaved deck. The dist rotor won't even make contact with the cap node, and you may not throw a crank sensor code. But try cranking it for a solid half minute and see if you get a code.
94dxt
Nov 3, 2009 02:02 PM
soulforce
Jul 17, 2006 12:41 AM
shiftgear8000
Oct 19, 2004 08:30 AM
lazynok
13
Jul 27, 2004 11:10 AM
FLATBLACKEG
Apr 5, 2004 09:29 PM
