"hondata s300 issue"
Old Nov 14, 2013 | 10:48 AM
coolvtec's Avatar
Default "hondata s300 issue"
Hi all,
I'm having problems with my s300 board.
I use to use it succesfully with p28 ecu with my previous set up. Then I broke the engine, put the engine out and left the car at the back yard for a few months.
After a while, we need to use it at my friend's car. But we couldn't able to connet to the ecu. It always gave us error message. Then we put a new base map in to it. We started the engine. The car worked but not properly, than it gave error code. We downloaded the map in to our pc and we saw that the base map deformed comletely as you can see in the pictures linked below. We tried the same ceremony again and again and but we always saw the deformed base map.
What we did to solve the problem;
1. We used the same s300 board with another ecu. result= the board deforms the base map.
2. We downloaded the newest version of s300 in to another pc which i,s virus free. result= the board deforms the base map.
3. We cleared/erased the ecu. result= the board deforms the base map.
do you know what the problem and the solutions are?
pictures
http://k1311.hizliresim.com/1h/g/ujvzv.jpg
http://k1311.hizliresim.com/1h/g/ujw16.jpg
http://k1311.hizliresim.com/1h/g/ujw26.jpg
Old Nov 15, 2013 | 04:58 PM
motoxxxman's Avatar
Default Re: "hondata s300 issue"
contact hondata tech support and give them the info on the board. ask them if it is actually a genuine hondata board. you may have a counterfeit board, and those do go bad pretty often. or your board may simply be bad, and hondata can assist you in testing it and possibly replacing it for free or for a lower cost than buying a new one.
Old Nov 16, 2013 | 12:59 AM
coolvtec's Avatar
thanx for your reply motoxxman. I'll try your advice.
I want to know there is nybody here who had the same issue. Nobody?
Old Nov 16, 2013 | 03:13 PM
VegasInvasion's Avatar
I'm Huge In Japan
it's not a board issue, it's a memory issue. unfortunately you'll have to replace the unit.
Old Nov 17, 2013 | 05:09 AM
coolvtec's Avatar
thanks for your reply VegasInvasion. Have you got any idea about what may be the reason of this issue, why did the memory go wrong?
Old Nov 17, 2013 | 07:24 AM
mtber's Avatar
1. Check if your hondata is genuine: http://www.hondata.com/s300_counterfeit.html
2. Contact the dealer you purchased the unit from to see if your unit is still under warranty. http://www.hondata.com/warranty.html
Old Nov 20, 2013 | 12:26 PM
I'm Huge In Japan
There are a few technical explanations for memory storage issues. In short, there's either a hiccup when translating and organizing the incoming information, or the memory itself is defective.
Either way it requires replacing components, which only Hondata can (legally) do.
MTBER has the bottom line though. It has to be replaced.
If it's counterfeit, you can get a discount on a new one. If it's under warranty, it "should" be exchangeable.
likwidchz
Engine Management and Tuning
Aug 9, 2016 05:12 PM
carlos8
36
May 4, 2014 05:42 AM
da9blk1
Aug 17, 2007 01:44 AM
