2000 Civic Si Hard Start Issues
Old Aug 4, 2013 | 01:31 PM
hoonigan21's Avatar
Icon6 2000 Civic Si Hard Start Issues
Hi Everyone,
I'm new on here. I recently purchased a completely stock 2000 Civic Si with 150,000 miles on it and zero rust. The previous owner had fixed a burnt exhaust valve and replaced an injector. Since buying the car I've been experiencing hard starts about 75% of the time regardless of whether the engine is hot or cold. The car starts after turning over once, sometimes twice or even 5 times. It just depends on the day.
Now here's my problem. I've gone over a lot of items on the car to try and solve this issue, including taking it to a shop and speaking to a dealership mechanic and I cannot track down this problem. The following is is list of things that I've either checked or replaced.
  • New Distributor (ICU included)
  • New Spark Plugs
  • Timing Adjusted
  • (2) Seafoam Treatments
  • Throttle Body Carbon Removal
  • Replaced Fuel Pump with used pump
  • Main Relay Checked -OK
  • Fuel Filter (New from previous owner)
  • New Fuel Pressure Regulator
  • Engine Compression -(Good/Average)
  • New Idle Air Control Valve
  • Throttle Position Sensor - (Idle 0.5v-4.44v WOT)
  • MAP (Visually Inspected)
  • Fuel Pressure Measured -OK
  • ECU Checked -OK
  • PVC Valve Inspected -OK
Does anyone have any suggestions for what I should do next? I really don't want to pay a dealership to go nuts tracking it down and charging me up the you-know-what.
Old Aug 10, 2013 | 02:04 PM
go-part's Avatar
Default Re: 2000 Civic Si Hard Start Issues
Have you had any testing done on the Crankshaft and Camshaft position sensors?
Old Aug 11, 2013 | 05:49 AM
hoonigan21's Avatar
No I haven't. Is that something that I could figure out on my own or have a mechanic do?
Mrintimidator33
Jul 19, 2018 08:01 AM
kobe2324
Feb 8, 2015 01:14 PM
hoonigan21
25
Sep 27, 2013 10:33 AM
xsuperxsonx
16
Sep 20, 2007 10:37 AM
rsbad454
Sep 25, 2003 10:28 AM
