Redlines when started HELP!!!
Old Jul 13, 2013 | 01:50 PM
Morford3288's Avatar
Post Redlines when started HELP!!!
Have b18b1 just changes all gaskets put back together and started for first time fired right up but rpms revved like I was hitting the gas and I wasn't at all so had to quickly shut off. I'm sure it's something minor but does anyone know what I could do? Please help!
Old Jul 13, 2013 | 01:54 PM
Orangevirus1's Avatar
Default Re: Redlines when started HELP!!!
check to make sure the throttle cable isn't holding the throttlebody open.
Make sure you completely tightened your intake manifold.
Old Jul 13, 2013 | 02:04 PM
Ill check the intake manifold but the throttle body isn't stuck open I checked that.
Old Jul 13, 2013 | 02:08 PM
Anything else I can check?
Old Jul 13, 2013 | 07:39 PM
VegasInvasion's Avatar
I'm Huge In Japan
huge vacuum leak. there's no other way it can do that if the throttle is closed.
Old Jul 14, 2013 | 08:17 AM
turbodcxbro's Avatar
^ gurantee its a big vacumn leak, you got something back together wrong...
Skunk2DC2
Aug 11, 2012 12:30 PM
fatpride111
Dec 5, 2008 05:57 AM
jyracer
Nov 10, 2008 05:05 PM
Sideshow9090
11
Nov 13, 2005 07:35 PM
carsaregood
Feb 28, 2002 07:23 PM
