1000cc ID's, hot start problem
Old Aug 14, 2013 | 07:52 PM
g2turbo's Avatar
Default 1000cc ID's, hot start problem
I'm having an issue starting my car when its warm/hot. It takes atleast 2 primes before it will fire even cold. When Hot sometimes it takes 3-4. Doesnt make sense as the car is making 90psi base pressure. Could this be something tune related?
Old Aug 14, 2013 | 08:16 PM
mtber's Avatar
Default Re: 1000cc ID's, hot start problem
The issue could be a lot of things including tuning, your ecu, ignition system etc.
Old Aug 17, 2013 | 08:12 PM
spoon_ek9's Avatar
at 90 psi static , your injector have a problem to get it open under cranking. unless your injector is calibrated correctly in your ecu, or else u will have the same problem no matter hot or cold.
Old Aug 19, 2013 | 08:24 AM
ls joker's Avatar
Loved
whats your cranking fuel trim set at
Old Aug 19, 2013 | 08:54 AM
Muckman's Avatar
Moderator in Chief
I've never had hot start problems with ID injectors that I've had with older style injectors. Play around with your cranking fuel at hotter ECT values.
Old Aug 19, 2013 | 08:56 AM
g2turbo's Avatar
thanks for the ideas guys, i'll check the values tonight to see for the cranking fuel trim.
Even when the car is cold I have to prime it twice before it starts, just doesnt really make any sense.
Old Aug 19, 2013 | 04:08 PM
g2turbo's Avatar
I took a screenshot of the settings for cranking trim (attached). I can email the .cal file if someone would be willing to take a look.
To clarify the issue, i have to prime twice (not crank, just prime) before starting cold, 3-4 times when hot. 90psi fuel pressure static, ID1000cc, Weldon 2040, walboro intake and 044 inline.
Thanks!
Old Aug 19, 2013 | 06:00 PM
mtber's Avatar
Make sure battery offsets are correctly set.
Adjust your cranking fuel trim etc.
Keep looking you will figure it out.
Old Aug 20, 2013 | 05:16 AM
2000CTRSi's Avatar
I like to calibrate my inj to where so much trimming is not necessary.
That's a lot of cranking fuel I feel.
dcivic91
May 8, 2020 06:22 PM
ChuckyStaytuned
Apr 29, 2015 04:21 PM
krazydbiker
Apr 4, 2007 08:48 AM
SiRkid
Sep 17, 2003 08:38 PM
