F10 in Crome?
Old Oct 2, 2013 | 05:13 PM
Freemananana's Avatar
Default F10 in Crome?
Okay. I'm new to crome, waaaay better than OBD0 rom editting. It was a good move. Anyways, F10 for the target AFRs doesn't work for me. Is there a plug in I'm missing or can you not set that while editting roms on your PC. It's the free crome too.
Also, the tables, is there a way to resize the boxes? Mine are small and the letters are actually being cut off from block to block.
I tried googling the target AFR window thing, maybe I installed something wrong or just missed it.
Last question, this is for a B16 motor. For base timing, to be safe, what is a good amount of retard? 1 degree per lb of boost? It should only run 11-12 PSI, which would be 12 degrees total retard. Is that enough? I don't want to melt this motor before it sees the dyno. It's a stock B16, tuning AFRs on the street before I get it on the dyno to do ignition timing.
Thanks.
adubaz7
Sep 6, 2007 05:23 PM
Running925
Apr 10, 2007 10:03 AM
kameleon23
Aug 23, 2005 08:53 PM
turbo Si
Feb 1, 2003 03:59 PM
echo999
Dec 31, 2002 11:28 AM
