hard butterfly
Old Oct 28, 2013 | 12:01 PM
samerharrouk's Avatar
Default hard butterfly
when i try to turn the butterfly of the throttle body on my engine it is so hard i changed my throttle cable yesterday but nothing hapened it still so hard what can i do?? i have a Honda Legend V6 engine 1988 (my car is a rover sterling)
Old Oct 28, 2013 | 05:54 PM
F22Master's Avatar
Default Re: hard butterfly
Remove the throttle body, disassemble it, clean it, sand/polish the shafts and bushings, grease the shafts and bushings, clean the inside (where the air flows), clean the throttle plate, and then reassemble.
Old Oct 29, 2013 | 09:07 AM
can i do it my self or i need a mechanic
Old Nov 4, 2013 | 04:21 PM
VegasInvasion's Avatar
I'm Huge In Japan
you don't even need to remove the throttle body, just remove the intake pipe, have someone hold the throttle down in the car and sand out the bore a little until it stops sticking. you may need to turn your idle screw down a little afterward since you'll likely experience a bit more idle air flow around the plate.
Old Nov 5, 2013 | 05:56 AM
motoxxxman's Avatar
bad idea, you'll get metal dust sucked into the motor.
take the throttlebody off to do it
Old Nov 6, 2013 | 02:37 PM
I'm Huge In Japan
or vacuum it out. a fraction of a milligram of carbon and aluminum particles is fully negligible.
NMJimCRV
Honda CR-V & Element
Oct 20, 2014 10:03 AM
ChevelleSSLS6
Nov 10, 2009 12:39 AM
Civic Hybrid
Jun 13, 2006 10:54 PM
Audi2Honda
Aug 19, 2002 06:58 PM
