two stock ecu's
Old Oct 5, 2013 | 11:22 AM
japcarmaniac's Avatar
Default two stock ecu's
many of you know that management for an auto d16 is not supported as much as it is for manual so i was thinking today.......
do you think it would be possible to use 2 stock ecus together? to be more specific what i mean is to have the original ecu wired up as normal then get another (same) ecu and bridge all the inputs over and use the second ecu as a source for 2, 3 or even 4 extra injectors that would work exactly the same as the original except now you have 50%, 75% or 100% extra fuel. mabey trigger them at a certain boost level so they dont over fuel out of boost. if it worked then perhaps a chiped ecu could be used to control fuel and timing then leave the stock one to control the transmission.
a bit extreme i know but its another option if thats the kind of **** ur into.
Violentpanda
Sep 11, 2018 02:57 PM
majdi
Engine Management and Tuning
Sep 14, 2011 07:09 PM
SKDRCR
Mar 6, 2009 06:48 AM
RTW DC2R
Nov 30, 2002 09:56 PM
94tegGSR_TypeR
Aug 20, 2001 08:30 AM
