chipped p75 or p06?
Old Oct 9, 2013 | 07:58 AM
supergohan's Avatar
Default chipped p75 or p06?
good day guys, just like the title says. i have a p75 ecu and a p06 ecu i would like to chipped but i would like to know which is better. its going to go on a 95 civic with a b18b1 engine swap with the basic air intake, headers and 2 inch pipe exhaust. its a daily driver i just want to get the most out of it with the basic set up. i would also like to go ls-vtec but thats in the future. thanx a lot in advanced and if anybody lives in southern maryland that can do it for me even better.
Old Oct 9, 2013 | 08:12 AM
Freemananana's Avatar
Default Re: chipped p75 or p06?
The P75 is OBD2 isn't it? I may be mistaken. The P06 will definitely work out for you if you plan on chipping it and tuning it for your set up. Without tuning it, it's just a best guess based on your set up.
Old Oct 9, 2013 | 08:17 AM
supergohan's Avatar
thanx man. the p75 is obd1 from a 1995 integra, they are both stock ecu. i was doing some research and they say that they need to be socket and stuff that kind of lost me but i'll keep researching.
Old Oct 9, 2013 | 11:22 PM
swordofdoom's Avatar
I Would go with the P06 since the P75 is a little bit more rare to come by and since your B18 is not vtec the P06 will do just fine.
Old Oct 10, 2013 | 02:49 AM
7rrivera7's Avatar
I suggest the P75 over the P06 becuase you can install a jumper on J1 (like I do) instead of a wire and by removing the jumper, your ECU will revert to stock which is for a B18 engine like yours.
PM me if you need the ECU chipped.
Old Oct 10, 2013 | 02:56 AM
Chipping is easy, if you don't know how to do it you can research or have someone else do it for you.
Old Oct 10, 2013 | 03:49 PM
supergohan's Avatar
i did some research i the subject and it looks doable. but what about the base map? it has to be bough online? after the chipping is done? 7rivera7 i will pm you once i figure out how to lol lol...sorry im new to this and i have two ecus and dont want to buy a new on just to chipped it
Old Oct 11, 2013 | 02:33 AM
7rrivera7's Avatar
You don't need another ECU to get chipped. I can chip either one of the 2 you already have. I can also convert them to VTEC and turn off this feature in the basemap until you swap in a VTEC head. Then all you have to do is actívate VTEC in the program.
Old Oct 11, 2013 | 05:24 AM
kyden's Avatar
it doesn't matter which one you use if you're going to chip it.
Old Oct 11, 2013 | 05:46 AM
Essentially. Use the P06 because the P75 has a better sale value as a stock ECU.
Getting an ECU chipped should be cheap. If I had a chip burner I'd get into that business.
Old Oct 11, 2013 | 06:14 AM
supergohan's Avatar
Ah ok I get it now , thanks guys I algo just found a p07 that I used to have . It's the vtec ecu that came with my civic vx thank a lot guys .
Old Oct 11, 2013 | 06:23 AM
7rrivera7's Avatar
Not usually, but in this particular case, having the P75 chipped with a jumper on J1 will allow him to bypass the chip and run a stock B18 map on his B18 engine if the chip or chipping circuitry fails.
xh22xcrx
Engine Management and Tuning
Nov 26, 2012 08:17 PM
ryanevansoh
Jan 13, 2009 08:50 PM
92yellowEG
11
Aug 24, 2007 01:13 PM
broketuner-Sol_Si
Nov 14, 2005 10:09 PM
VtecbOi
Mar 30, 2003 07:06 PM
