Serial Logging Anyone do it?
Old Aug 21, 2013 | 07:36 AM
ZCHondaCRX91's Avatar
Default Serial Logging Anyone do it?
Has anyone used the serial logging straight from the wideband unit (in my case LC-1) directly to the laptop and used that to tune in the tuning software? Seems like that would be the most accurate way to tune, without needing to do offsets. I tried it in Neptune RTP and it works fine but the gauge is a little different so I don't know which one to trust (the gauge or serial output).
Old Aug 21, 2013 | 01:08 PM
HRTuning's Avatar
Default Re: Serial Logging Anyone do it?
There's no offsets for serial data, so whatever it says via serial is what it's seeing at the wideband controller.
Old Aug 21, 2013 | 01:19 PM
xenocron's Avatar
Use it all the time in eCtune and Neptune...best feature I ever got added to these two systems!
Old Aug 21, 2013 | 01:45 PM
2000CTRSi's Avatar
I also have implemented the serial logging from an aem uego by making a (d3?) connector from the (blue) data wire and a ground, logging afr via hyperterminal and evoscan when tuning evos on stock ecu.
Old Aug 21, 2013 | 02:31 PM
Thanks guys, I'm going to just use that now. I always thought it was complicated to setup, but it was simple.
Old Aug 22, 2013 | 02:42 AM
7rrivera7's Avatar
ZC or anyone else that has done this, can you post details on the setup. It's an excellent idea!
Old Aug 22, 2013 | 06:59 AM
Basically all I needed to do is hook it up to my laptop like I would in the instructions (LC-1). Then in Neptune I set it up under preferences (says in Neptune what to do), then you just hit start serial logging and it's set. I wish I would of saw it a long time ago.
deeweezy187
Jan 15, 2008 06:45 PM
X2BOARD
Dec 7, 2007 08:16 AM
dmotoguy
Nov 17, 2006 01:39 PM
donkiman
Dec 9, 2004 01:23 PM
BodyKits NW
Aug 28, 2004 04:36 PM
