Direct Serial Logging with MTX-L in Neptune
Old Sep 29, 2013 | 08:44 AM
averyvm's Avatar
Default Direct Serial Logging with MTX-L in Neptune
I just recently started direct serial logging. I used to log from the ecu but the signal was intermittent. The direct serial was working just fine for two minutes and then it would start acting very buggy. I posted a picture of the datalog playback above. What would cause this signal to stop coming through the way it should. I wonder if its the serial to usb converter?
Old Sep 30, 2013 | 05:36 AM
HRTuning's Avatar
Default Re: Direct Serial Logging with MTX-L in Neptune
Like I mentioned, check the advanced settings (Latency). If both of your signals from this wideband have been intermittent... You probably have a problem with it. Contact the manufacturer to see what they suggest. Test with their software as well.
175Shot4Door
Apr 20, 2010 05:42 PM
silverbur
Feb 5, 2008 01:42 PM
HondaDC4Integra
Feb 9, 2007 07:55 AM
slojo-nogo
Jul 28, 2006 05:04 PM
Vtakkk
Mar 26, 2006 02:38 PM
