Aem EMS Starter Kickback
Old Jul 12, 2013 | 03:24 AM
honda_12V's Avatar
Default Aem EMS Starter Kickback
Hello,
I have had my ems for a year. I tune it myself as i do not have local aem tuners in my country.
In this year, i worked out most of the aspects of the box, my car drives well, on the street and highway, idles well, I have no issues, I have lifted my head twice in this year and have no signs of detonation or pre ignition.
I check my spark plugs often they burn well, i have not blown a set or caused any damage to them. I have got the traction control, launch control dialed in and am very happy with my EMS.
The one problem that has killed me so far is getting the car to start perfectly.
My car does start on the EMS, when its warm rather easily with a 2-4 cranks. On cold its much more difficult but does come in line after a few cranks.
BUT no matter what i change or do, I cant stop it kicking back on start. I have blown 3 starters in the year and have tried almost everything. Read many forums indept but nothing seems to help. The starter does a kick back, Or it just hits a wall like there is no battery power to run it - i keep a eye on the battery voltage that normally happens when volt drops below 9, i guess that is normal.
Below is a list of things i have tried over time.
1. Played numerous times with crank advance - increase or decrease make no difference.
2. Had the crank inject ON mostly, read a thread yesterday suggesting it should be OFF> got it off now car starts 2% better than before.
3. Innitial crank pluse - read a forum about increasing it on some tps points so you can have like a band aid - like on a crab car open throttle throw some extra fuel to make it start easy, helps but wont stop kick back.
4. NO warm, the car starts well sometimes in 1-2 cranks but it still kicks back.
5. I give the EMS time to prime i dont fire it up start away.
6. Start sync comes on just after 1 crank IMO
7. Battery holds well got 10-12.5 volts while cranking
8. Have had the grounds checked at numerous occasions. Also introduced a ground wire from the starter bolt to battery
9. I have made sure over and over that my ignition timing is synchronized between engine and ecu
Lately I have been considering to make a start up cal in line with what i got from AEM. As in AEM base map uses ID1000 injectors. I use stock. So if the value at 20 degree is 15ms for aem I did a small calculation - 14x1000/290 = 48 on my map. Am going to try this tonight but i dont have high hopes.
The setup is a G23 inside a accord. RUnning stock intake, alfa 70mm tb and 290cc injectors. Am using a 30-6050 EMS series 2 ecu
Can anyone shed some light, I can post the cals or make logs if required. Its just getting very frustrating for me. Am even considering selling the EMS and getting a Hondata. But it breaks my heart, i am not the kind of person to give up on something quickly. I really want to learn and cover this, if i have been cover the rest thing should not be impossible.
Any help / assistance / even criticism is welcome.
Kind Regards
Old Jul 12, 2013 | 07:39 AM
Rtype16's Avatar
Default Re: Aem EMS Starter Kickback
Post a link to your calibration so we can take a look at it.
Old Jul 12, 2013 | 08:19 AM
honda_12V's Avatar
http://www.sendspace.com/file/oi88qx
Here you go.
Just keep in mind its stock 290cc injectors that is why i have to add so much fuel.
Old Jul 12, 2013 | 09:58 AM
accorse07's Avatar
Try Lowering your crank advance a bit more. Even at 6.9 degrees, the combustion may be an ideal mix that is causing kickback.
I would go to 0 if you are on your 4th starter this year.
Old Jul 12, 2013 | 10:01 AM
honda_12V's Avatar
I just tried 0 and it does not work.
Seem starter 5 is coming soon.
Am thinking of switching to hondata and making my life easy.
Am frustrated with this.
Regards
Old Jul 12, 2013 | 10:47 AM
2000CTRSi's Avatar
Too much fuel, too much adv.
Old Jul 12, 2013 | 07:49 PM
honda_12V's Avatar
Anny others?
Old Jul 14, 2013 | 07:39 AM
Turbogixxer's Avatar
Buddy had the same issue and it converted to external coil (still OEM coil) and it went away. Try it.
Old Jul 14, 2013 | 07:58 AM
honda_12V's Avatar
Yeah i read that too.
So best external coil setup for me would be epm + k20 coild and a harness?
Regards
Old Jul 14, 2013 | 08:00 AM
He just did the external h22a coil and it worked great.
Old Jul 14, 2013 | 08:11 AM
honda_12V's Avatar
Could you please explain how do i do that?
I have a msd sci at home, is that the same thing?
Old Jul 14, 2013 | 08:13 AM
OBD1 accords and preludes have a external coil. You can use that coil and cap, convert the wiring to external and see if it helps.
Old Jul 14, 2013 | 08:29 AM
honda_12V's Avatar
That is very interesting. I will get on to that in the week. I am lucky i have a F20z1 1993 distributor at hand.
Do you think the msd sci would be good addition to the system?
Regards
Old Jul 14, 2013 | 08:53 AM
MSD will not help in any way.
Old Jul 14, 2013 | 08:58 AM
honda_12V's Avatar
Thanks alot of the idea sir.
I will get cracking on the external coil tomorrow itself
Old Jul 15, 2013 | 11:57 AM
Rtype16's Avatar
Sounds like you just need a proper tune on the car. Unfortunately I can
t download your file as that website is blocked at my work.
Old Jul 16, 2013 | 02:17 AM
honda_12V's Avatar
Rtype16, pm me your mail ID i will email the file to you.
I agree i need a tune, but like i explained i dont have a tuner local thus its all down to my shoulders.
Old Jul 19, 2013 | 06:48 AM
2000CTRSi's Avatar
Billspectuning@gmail.com
I will take a look at it as well
Old Jul 19, 2013 | 07:30 AM
honda_12V's Avatar
2000CTRSi... thanks for the email.
Cal SENT
Regards
Old Aug 4, 2013 | 04:34 PM
Flr Power's Avatar
Do you have the engine kick back fixed?
Old Aug 9, 2013 | 05:34 AM
c5R's Avatar
c5R
if you convert the car to COP this problem will go away. Its been a issue with low speed cam and crank signals for years on the aem. You can use the aem epm and 4 k series coils. However the issue can be fixed in the tune but it takes some work and will still do it every now and then.
Old Aug 9, 2013 | 06:37 AM
Flr Power's Avatar
I know the kick back starting can be fixed because it no longer does it on my own car. It took me over a year experimenting with different calibrations and engine with distributors are the most likely to kick back with just a small calibration error.
0ptimus prime
Engine Management and Tuning
Apr 6, 2019 11:07 PM
vietdragontekx
Honda S2000
Jan 23, 2012 01:02 PM
H22SkeetSkeet
Honda S2000
18
Dec 22, 2007 04:58 PM
sirguy01
Oct 28, 2006 03:43 PM
sportridermike
Honda S2000
May 26, 2005 02:56 PM
