Chipped ecu re-install
A little while back I was having trouble with my chipped p06 ecu. I was stuck in limp mode and it was throwing a code 4 for ckp. while this was happening I had unplugged other sensors to see if my ecu would process the fault code, it did. My obd1 conversion harness had weakend solder joints an I noticed several were just starting to fall off. I didn't want to risk anymore so I took out my dsm 450's and threw the stock injectors back in, and my p28 stock ecu, also unhooked my charge pipe w/ blow off valve. now my car runs great in stock form.
I had recently purchased a new obd1 conversion harness, loaded a stock basemap onto my chipped ecu. Even with the new harness I still am in limp mode. Just trying to troubleshoot my ecu. It doesent seem to be fried if it processes new fault codes when im unplug them. Does anyone have any advise for me? would be greatly appreciated. Thanks in advance
Who is Mr Robot?
^I agree
open the case on your chipped ecu and check every solder joint at the board for the ecu plug pins, sometimes over the years vibration and repeated ecu plug removal can cause them to come loose
Yes no code 4 and no limp mode to have to endure when I put my stock ecu in. Runs great with the same dizzy and stock ecu. Safe mode with the p06. I can't stand safe mode. Drives me crazy. Lol. I'll look at all the solder joints tonight.
Sorry bro but it was a typo it's a P2E, that's weird. So I would still need a P2E ecu then right because they're better than a p06?
Well the reason I bought the p06 is because I'm running a non vtec motor. The ecu was working great for about 1.5 yrs then just **** on me mid pull on a Tiburon. Still beat him. he kept coming back for more. lol. I think it was an NA motor in it.
00k20em1
23
Sep 28, 2016 04:57 PM
