Fuel pump dead?
Old Sep 27, 2013 | 09:20 AM
Brizzle242's Avatar
Icon2 Fuel pump dead?
I have a 96 CX hatch with a Frankenstein swap (b16 head/b20 block) and one day I took my battery out and had the car sitting for a few days....maybe a week or so, and when I put the battery back in, and turned my key on, I only could hear my radiator fan, normally I would be able to hear the fuel pump over the fan....I started the car and it ran for a few seconds then died out..could this just be a situation where no power is getting to my fuel pump or the pump itself has burned out or died? The pump that's currently in the car is a Walbro 255 lph pump..can anyone give any advice/ help me?
Old Sep 27, 2013 | 09:57 AM
motoxxxman's Avatar
Default Re: Fuel pump dead?
fix your fan, it shouldn't be running at all unless you have the a/c on or the radiator is too hot.
walbro pumps are fairly indestructible. if it's not working, it probably just isn't getting any juice
Old Sep 30, 2013 | 06:30 PM
VegasInvasion's Avatar
I'm Huge In Japan
fuse might have blown while reconnecting the battery. otherwise check your main relay and ECU connections, try replacing both to rule them out.
boost16awd
10
May 19, 2017 10:21 AM
veritasaequatis
Classic Hondas
Feb 20, 2009 05:32 PM
boostnubII
Oct 23, 2006 07:52 PM
Cee_mon
13
Apr 27, 2005 12:08 PM
Gman8941
Jul 18, 2004 07:37 PM
