New IM causing problems! Help!
Old Sep 24, 2013 | 04:13 PM
JHipps's Avatar
Default New IM causing problems! Help!
Okay guys here is the rundown on my car. If you need any more info please ask.
B16 Head
-Supertech Springs/Retainers
-Stock Cams
B18A1 Block - Stock
Garret gt28r .60 trim turbo
2.5' piping all around
750cc r/c injectors
So I had the stock intake manifold and throttle body on there. I bought a Performer X intake with a Pro. Products 65mm TB. The TB came with TPS and Map sensor. My b16 did not have a map sensor on it. When I start it up, my air/fuel reads 10.0 and smoke comes out the exhaust. Soooooo I am not sure what to do from here.. Any help will be appreciated
Old Sep 25, 2013 | 07:52 AM
Rtype16's Avatar
Default Re: New IM causing problems! Help!
What kind of engine management do you have on the car? Is it tuned? Did it run before on the stock manifold and your setup?
Old Sep 30, 2013 | 06:32 PM
VegasInvasion's Avatar
I'm Huge In Japan
my money's on the MAP sensor. use the one on the firewall if that's what you were using before. either that or you have the MAP and TPS plugs backwards
JHipps
Sep 25, 2013 01:23 PM
A BOOSTED CRX
Mar 28, 2008 04:25 PM
99hondacura
Mar 28, 2008 11:39 AM
B16A CRX
Jul 9, 2007 06:14 PM
88crxhfb16
Apr 16, 2005 05:59 PM
