obd2a lsvtec
Old Oct 4, 2013 | 08:20 PM
j13's Avatar
j13
Default obd2a lsvtec
couple months ago I went lsvtec. got the engine fully rebuild, its a b16 head over a 1996 ls block. runs smooth, I added the head and intake manifold, everything else is just my recycled ls parts to make it run. I wanna keep it obd2 while having vtec. how can I make an obd2a vtec ecu work on my car without throwing a cel for a knock or other things. what's my best option as far as a vtec ecu. thanks in advance
Old Oct 5, 2013 | 07:40 AM
j13's Avatar
j13
Default Re: obd2a lsvtec
nobody
Old Oct 5, 2013 | 06:52 PM
j13's Avatar
j13
anyone
Old Oct 5, 2013 | 07:37 PM
mtber's Avatar
Your obd2 ecu can't be modified with any solutions on the open market.
Read http://www.phearable.net/tech/efibeginnerguide.html
Old Oct 5, 2013 | 08:20 PM
swordofdoom's Avatar
I really just want to do this:
http://www.sadanduseless.com/wp-cont...13/10/sc13.jpg
Old Oct 5, 2013 | 08:27 PM
j13's Avatar
j13
thanks for the response, I know obd2 can't be modified, I was wondering if I can just use a 1997 integra type r ecu, I'm sure it has a knock sensor is there a way I can still run it? ls blocks dont have a knock sensor
Old Oct 5, 2013 | 10:10 PM
raverx3m's Avatar
ecu goes to open loop under high load.
aka LS vtec is not the same as ITR motor and wont run properly in vtec or under high load.
get an obd1 chipped ecu and jumper harness for it and tune
even a slight change like intake and exhaust can throw your car in very lean condition at higher rpm...
EK Ryda
Feb 1, 2011 05:38 PM
Built4Battle
Jan 23, 2011 09:46 AM
allmotorb18c14door
Jan 31, 2010 02:31 PM
lukehowell88
Nov 11, 2007 01:39 PM
crispchris
Jun 28, 2007 09:00 AM
