p28-a51 ecu
Old Sep 21, 2013 | 11:42 PM
raverx3m's Avatar
Default p28-a51 ecu
I just picked up that ecu from junkyard it looks to be one of the factory chipped ecus
does it mean that I can desolder the oem chip and put the crome programmable chip instead?
Old Sep 23, 2013 | 03:17 AM
7rrivera7's Avatar
Default Re: p28-a51 ecu
Yes, but use a socket '-)
Old Sep 30, 2013 | 07:04 PM
VegasInvasion's Avatar
I'm Huge In Japan
There are no OEM chipped P28s on earth. P28-A51 simply means it's for automatic. The chip is aftermarket, or was installed by an authorized dealer (the good old days before pass-thru).
Be sure to perform an auto-manual conversion on the ECU if you're tuning for a manual transmission. If you're tuning for an automatic, I would suggest trying to salvage the existing chip and start with that base.
Old Sep 30, 2013 | 08:16 PM
raverx3m's Avatar
I just took It to use with crome chip for b series
so I don't have to chip it completely it was in a car with d15b im assuming it was jdm
93 civic 2 door
Old Oct 1, 2013 | 11:25 AM
I'm Huge In Japan
manual conversion might have already been done on it. good luck getting the chip out. I'd suggest cutting off the legs first and pulling the legs out one by one instead of trying to desolder the whole things and roasting the vias.
Old Oct 1, 2013 | 12:00 PM
raverx3m's Avatar
yeaaa like bugs haha. isn't there some kind of desoldering liquid I can use?
Old Oct 1, 2013 | 01:51 PM
92cxturbo's Avatar
Desoldering those factory chips can be a pain, and you will more then likely lift a trace if your not very experenced at desoldering. Your better off paying someone who has done it a few times or you'll probally end up needing another ecu.
Old Oct 1, 2013 | 01:53 PM
92cxturbo's Avatar
I've seen a few obd1 ecu's that are factory "chipped" from honda it's not aftermarket.
Old Oct 1, 2013 | 02:51 PM
Spunkster's Avatar
Was about to say the same thing
Old Oct 1, 2013 | 10:10 PM
raverx3m's Avatar
according to the internet there was a revision on 1993 model civics
I don't know if this one had original engine but it had a d15b which is a jdm d series vtec (not dual stage vtec)
heres the car I pulled it out of
http://row52.com/Vehicle/Index/1HGEJ1265PL055189
Engine 1.6L L4 SOHC 16V
Trans 4-Speed Automatic
Trim EX coupe
Vin 1HGEJ1265PL055189
Old Oct 2, 2013 | 03:19 AM
7rrivera7's Avatar
I've socketed MANY OEM chipped ECUs. You can tell it's OEM because the chip has a GOLD patch in the middle of the chip. If you need someone to socket that ECU PM me.
Old Oct 4, 2013 | 03:57 PM
I'm Huge In Japan
They were not manufactured by IPT or Denshigiken; they were installed using open market components by a dealership or electronics shop. This was done for recalls and C.A.R.B. obligations before pass-thru was available.
That's a UVEPROM, they were used by all chip tuners before EEPROMS were developed. The gold patch is applied to block out UV light so the chip doesn't erase itself.
All OEM electronics are ROM only.
Old Oct 4, 2013 | 04:04 PM
I'm Huge In Japan
Coat both sides of the vias in soldering flux and add new solder to dilute the joint if needed.
Do NOT use desoldering braid; use either a solder sucker or desoldering station and remove the solder from the back of the board.
OR if you don't care about the old chip, just snip off the legs right at the chip, remove the body, and heat up each hole individually as you pull out the legs.
When it's removed you can use a small sharp pin tool (common in soldering tool sets) and hollow out the vias with that instead of desoldering again. This is often safer since the boards are brittle and can't handle much heat.
If you don't have all of these tools already, just pay someone to do it. It'll probably save you money.
Old Oct 4, 2013 | 04:24 PM
7rrivera7's Avatar
I enjoy learning - thanks for that Vegas ;-)
Old Oct 4, 2013 | 08:59 PM
raverx3m's Avatar
I have the tools I ve done many ecus was just wondering to keep the chip or not. is it any use at all? or d15b maps from that chip already available for download?
Old Oct 5, 2013 | 11:01 AM
I'm Huge In Japan
yeah it's just the P08 maps, which you can import to the P28 A/T rom if you wanted to duplicate it for some reason.
Vtec140
Oct 3, 2017 02:15 AM
I CRX I
Engine Management and Tuning
Feb 18, 2010 08:09 PM
WeB
Jan 19, 2010 11:17 AM
BUDtoker
Nov 6, 2007 06:24 PM
