OBD1 data logging via Andriod
Old Oct 16, 2013 | 09:35 PM
swordofdoom's Avatar
Default OBD1 data logging via Andriod
Ok, just wondering if anyone has tried the OBD1 Data Logging app for the Android on their phone for a Crome chipped ECU?
Reason I am asking is that I am soon going to dive into the Wireless logging scene and just wanted to ask who has had success and failures.
Old Oct 17, 2013 | 04:14 AM
Freemananana's Avatar
Default Re: OBD1 data logging via Andriod
Didn't know there was a wireless datalogging app at all. Want to tell me how it works? Sounds pretty cool. Not sure how my P28 sends information to my phone. What hardware is required?
Old Oct 17, 2013 | 03:27 PM
The app can be downloaded on the google play store (Honda Obd1 datalog). What I am working on is the communication between the ECU, Crome Pro and phone via bluetooth for a chipped ECU. Does not work with a stock ECU! The hardware right now is a hit, or miss since I don't have it yet (Still in the mail).
Heres the Video:
Old Oct 17, 2013 | 07:17 PM
HRTuning's Avatar
Not hit or miss at all if you go with quality components, but most people go cheap. Sparkfun has some reliable units, which is what I recommend for use with NepTune.
Old Oct 17, 2013 | 08:42 PM
Im looking at the Cheaper $10 range stuff!
Old Oct 18, 2013 | 06:08 AM
HRTuning's Avatar
Then you'll get hit or miss... and part of that is the class of the bluetooth chip. That has a huge effect on power, range, and susceptibility to noise.
Old Oct 18, 2013 | 09:17 AM
SQ is the SQUAD's Avatar
i use the app, it works. i have the electhouse usb unit which is about $20 on ebay.
http://www.linszter.net/?lang=en for more info
Old Oct 18, 2013 | 10:38 AM
Peter Linszter's Avatar
I got lots of emails, and some people said my app is not working. Usually the problem is the bluetooth device. I only tested the elechouse device yet, but sometimes it need set up correctly. I don't know which other one works, and which not. I ordered some other cheap bluetooth device, and i will test it.
Old Oct 18, 2013 | 03:07 PM
Cool thanks for contributing Peter.
Is there any future support to show what Map table cell your looking at for Crome / ectune?
Old Oct 18, 2013 | 09:49 PM
You mean something like that:
Old Oct 19, 2013 | 12:47 AM
I guess thats close enough.....
Old Oct 20, 2013 | 05:19 PM
I got the bluetooth module to work today with the andriod app. It took a while to program the bluetooth since it was a HC 06 version and not an HC 05 like the one on Electric house....maybe ill add a review of it later.
Old Oct 21, 2013 | 03:17 AM
7rrivera7's Avatar
I use and promote Peter's APP with the Elechouse Bluetooth adapter here in Puerto Rico and have not had any issues.
Old Oct 21, 2013 | 06:44 PM
spAdam's Avatar
Loved
Community Favorite
I've had pretty good luck with the bluesmirf chip in some projects that I have done, both for work and play.
The class of the chip absolutely matters, especially in the cabin of a car and more so if you plan on enclosing it in an ecu. The cheapo chips just won't cut it if you want reliable communication.
Old Oct 23, 2013 | 09:27 PM
From what I can understand the communication tends to receive some noise every now and then causing the data to be displayed to jump to high numbers. I am not sure if its just the bluetooth adapter but much more testing is needed considering that its the same main chip but in a different circuitry, firmware and being tested on the bench instead of an actual car.
Old Nov 8, 2013 | 09:03 PM
I need a bit more tester for 2.0 beta. If you interested, you need to join to this Google+ Community: https://plus.google.com/communities/...02651317095441
Then you can join to beta testing here: https://play.google.com/apps/testing...r.hondadatalog
New features in 2.0 beta:
- Crome QD3 datalog protocol (Crome Gold)
- GPS and G sensor logging
- New gauges
- Video recording and logging same time (You can use RaceRender2, to make overlayed gauges on the video. Sample:
- The app make a summary file on the end of logging which contains Elapsed time, Distance, 0-100kmh (0-62mph) time, 0-402m (1/4 mile) time, Highest rpm/speed/boost, Average rpm/speed. This summary file can be uploaded to my website: http://www.linszter.net/linszterdatalog/
Old Nov 13, 2013 | 09:31 PM
Perhaps I will!!
Old Dec 22, 2013 | 06:48 PM
The new version is on the Google Play Store, now with Crome Gold (QD3) support
Old Dec 23, 2013 | 04:56 AM
spAdam's Avatar
Loved
Community Favorite
Very cool work man.
Old Jul 27, 2020 | 08:05 PM
Picu10's Avatar
Hi, I wanted to know what configuration you did to the hc because I tried several and I do not find the problem of the datalog
Gavin G
11
Jul 4, 2014 12:02 PM
amadeuscr
Jun 21, 2010 09:54 AM
SidewayzCivic
Apr 27, 2010 04:48 PM
Tommy_Gunns
Nov 25, 2001 05:40 PM
