b16 issue
Old Oct 19, 2013 | 03:19 PM
zayne's Avatar
Default b16 issue
hello yall, im new to the site but have read a lot of tech posts.now I need serious help. I have a 95 ex coupe that I swapped a b16 into,it had an ls when I bought it. anyhow the ecu is a chipped p28 with a modified p30 basemap, now my issue that I cannot figure out for the life of me is my engine will not rev past 7200. I have double checked the tune and even raised the rev limit to 9500 to eliminate a faulty tach,and no luck.it just hits a rev limit it croses vtec and all it pulls normal but wont rev out...I pulled codes and got 10(intake air temp) and 14(idle air control) and an o2 code I cant figure this out and could use some expert advice. thank you
Old Oct 19, 2013 | 10:54 PM
jbpnoman's Avatar
Default Re: b16 issue
How exactly did you raise the rev limit?
Old Oct 19, 2013 | 11:10 PM
purgat0ry's Avatar
I'd get those codes fixed before I tried to rev a B16 way past what it should rev to anyway...
Old Oct 20, 2013 | 04:53 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Fix the codes.
Old Oct 20, 2013 | 07:19 AM
zayne's Avatar
We raised the rev limit thru the tune the ecu is chipped on chrome and dont worry i never intend to take it up that high that was mostly to test to see if the tac was off also i have no clue how to fix those codes... I do have to ask this. My ect on the side of the block had tobe sliced into the harness and i dont know which wire go where i swapped the wires around and it never thru a code could the ect be bad and keeping the ecu in cold start mode even after its warm
Old Oct 21, 2013 | 07:41 AM
zayne's Avatar
No ideas at all? Anyone?
Old Oct 21, 2013 | 08:03 AM
93egSLEEPER's Avatar
Again...fix the codes and report back. The CEL comes on for a reason, and it stops revving...for a reason.
Old Oct 21, 2013 | 09:11 AM
doctorake's Avatar
Community Builder
Just search this site for how to fix the codes, it is pretty easy. Also get a FSM(factory service manual), downloaded off the web.
Old Jan 30, 2014 | 08:05 PM
zayne's Avatar
Trying to bring this thread back...i fixed all codes which was iacv and god am i happy that it doesn't bounce at 1500 however it still only revs to 7200 and feels like you hit a. Rev limit
Old Jan 30, 2014 | 08:10 PM
NotARaCist's Avatar
I never narc'd on nobody!
Then you didn't correctly raise your rev limiter (there is more than one limiter), or Chrome is stopping you from doing something stupid.
Old Jan 30, 2014 | 09:18 PM
zayne's Avatar
Not sure what you mean by more than one rev limiter im going to try a different ecu with a different chip tomorrow could there be something in the dizzy causeing an issue
Old Jan 31, 2014 | 12:35 AM
driguy's Avatar
Yes, you probably are hitting a rev limit. And with good reason. So you don't blow up your engine. The rev limit on most of the b-series engines is set around 8200 RPM, correct? What is the reason you want to go past 7200 in the first place?
As far as something in your dizzy causing an issue? Highly doubtful. It's pretty apparent what your issue is and it has nothing to do with anything mechanical at all.
Old Jan 31, 2014 | 01:07 AM
qharr1's Avatar
Sorry a little off topic, but! you mentioned it doesn't bounce at 1500?
do you mean, a hesitation in revs and jerk around this rev range?
reason i ask is because, i have this problem and have tried so many different things to fix my problem but cant seem to find a solution.
Old Jan 31, 2014 | 05:27 AM
redberan1's Avatar
Seriously??? isnt that why they made these motors? they didn't put a b16. into an EM1 and slap an 8k tach on it so you could short shift it at 7200. ****** stupid question.
OP, I'm not sure if you said the vtec was engaging at 5800 like normal? but I was thinking the tach could be off, I've seen that happen. grab a friend's tach and try it. otherwise it's definitely something electrical. I'd try a virgin stock ecu.
Old Jan 31, 2014 | 07:44 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
OP...try swapping in a OBD1 P30 or OBD1 P72 (stock) ECU. Maybe there's something wrong with your chip or programming.
Old Jan 31, 2014 | 09:04 AM
zayne's Avatar
My rev limit on my tune is set at 8500 its still in the same range as stock also the only reason i would like to rev like the b16 should is everyone knows b16 dont really build power untill vtec well qhen i try to run people and i have to shift at 7 it puts me out of vtec and then ifa like driving a b7 motor....and for the bounce issue it was just at 1500 rpm buddy it was a side affect of my iacv not being hooked up
Old Jan 31, 2014 | 01:42 PM
zayne's Avatar
Well i tried a differnt ecu that i know revved out and still the same issue i put my ecu in the other car and it revs out fine so it must be something else
demastus18
Jul 28, 2014 02:27 PM
tatmark1
22
Jul 19, 2006 01:36 PM
95LStizzy
Mar 2, 2006 04:38 PM
teler86
14
Nov 27, 2004 01:26 PM
sicivic
12
Jan 23, 2002 06:46 PM
