FAQs - Frequently Asked (Tech) Questions
Old May 29, 2007 | 10:45 AM
Syndacate's Avatar
Icon2 FAQs - Frequently Asked (Tech) Questions
This is the Frequently Asked Questions (FAQs) thread for the 92-00 Civic/Del Sol subforum.
Notes To Contributors
  • Any suggestions for improvement of this FAQs thread are welcomed, encouraged, and appreciated. PM @Former User your comments and suggestions.
  • We are always looking for new content to include in this FAQs sticky. Please give back to the Honda-Tech (H-T) community. When you do a job on your car, take the time to create a FAQ/DIY thread. When you do so, please upload the pictures at a reliable and stable site.
  • Over time, the pictures in some H-T DIY threads have been lost. If you have a picture(s) that could be used to repair such threads, please contact us.
  • If you find good write-ups while browsing on H-T or other sites or you find bugs, broken links, or incorrectly named links in this FAQs sticky, please let us know.
Looking to make your car FASTER? Reading these two critical guides (Grumblemarc and EsotericImage) will SAVE YOU MONEY and TIME.
Table of Contents
1. Parts, Installation Templates, Common Problems, and Mechanic’s Tips
2. Vehicle Security, Storage, and Purchase
3. Vehicle Specifications and Maintenance
4. I Just Bought a Civic! How Do I Make It Faster?
5. Engine
a. General Information
b. Ground Wire Locations
c. Removal
d. Diagnostics and Treatments
e. Tune Up and Lubrication
f. Oil Leaks - Seals, Gasket, O-ring
g. Ignition System/Distributor
h. Timing Belt and Valve Train
i. Cooling System
j. Header and Exhaust
k. Fuel System
l. Air Intake and Idle Control
m. Emissions
6. Engine Mods, Swaps, Builds, Tuning, and Appearance
a. Mini-me
b. Forced Induction
c. Swaps
d. Builds
e. Tuning
f. Appearance
7. Manual Transmission
a. Fluid
b. Removal and Disassembly
c. Swaps
d. Gear Ratios
e. Clutch
f. Shifter
8. Automatic Transmission
9. Axle
10. Suspension and Steering Rack
a. General Suspension
b. Ball Joint and Wheel Bearing
c. Strut and Spring
d. Front/Rear Sway Bar, Traction Bar, End Link, Trailing Arm
e. Bushings
f. Steering Rack, Tie Rod, Tie Brace
11. Steering Wheel and Horn
12. Wheels and Tires
13. Brakes
a. General
b. ABS
c. Conversions
d. TCS (Traction Control System)
14. Interior
a. General
b. Leak
c. Trunk
d. Seats
e. Dashboard
f. Door Panel and Window Regulator
15. Exterior
a. Paint
b. Body
c. Hood
d. Doors, Windows, Mirrors
16. Climate Control
a. Blower
b. Heater
c. Air Conditioning
17. Electrical
a. General and Common Problem Troubleshooting
b. Charging System
c. Starting System
d. Ignition switch and button
e. ECU
f. Sensors
g. Cluster, Gauges, and Dash Lighting
h. Power Windows, Power Locks/Keyless, Security System, and Power Mirrors
i. Wipers, Combination/Wiper Switch, Dome Light, and Chime
j. Exterior Lights
k. Cruise Control
l. SRS
18. Track Times
19. Other FAQs
FAQs Links
1. Parts, Installation Templates, Common Problems, and Mechanic’s Tips2. Vehicle Security, Storage, and Purchase3. Vehicle Specifications and Maintenance4. I Just Bought a Civic! How Do I Make It Faster?5. Engine
a. General Informationb. Ground Wire Locationsc. Removald. Diagnostics and Treatmentse. Tune Up and Lubricationf. Oil Leaks - Seals, Gasket, O-ringg. Ignition System/Distributor (mostly diagrams)h. Timing Belt and Valve Traini. Cooling Systemj. Header and Exhaustk. Fuel Systeml. Air Intake and Idle Controlm. Emissions6. Engine Mods, Swaps, Builds, Tuning and Appearance
a. Mini-meb. Forced Induction (Also see the Forced Induction subforum)c. Swapsd. Buildse. Tuning (Also see the Engine Management and Tuning forum)f. Appearance7. Manual Transmission
a. Fluidb. Removal and Disassemblyc. Swapsd. Gear Ratiose. Clutchf. Shifter8. Automatic Transmission9. Axle10. Suspension and Steering Rack
a. General Suspensionb. Ball Joint and Wheel Bearingc. Strut and Springd. Front/Rear Sway Bar, Traction Bar, End Link, Trailing Arm e. Bushingsf. Steering Rack, Tie Rod, Tie Brace
11. Steering Wheel and Horn12. Wheels and Tires13. Brakes
a. Generalb. ABSc. Conversionsd. TCS (Traction Control System)14. Interior
a. Generalb. Leakc. Trunkd. Seatse. Dashboardf. Door Panel and Window Regulator15. Exterior
a. Paintb. Bodyc. Hoodd. Doors, Windows, Mirrors16. Climate Control
a. Blowerb. Heaterc. Air Conditioning (A/C)17. Electrical
a. General and Common Problem TroubleshootingEngine Ground Wire Locations (see Engine section 5b)
b. Charging Systemc. Starting SystemIgnition System (see Engine section 5g)
d. Ignition Switch and Buttone. ECUf. Sensorsg. Cluster, Gauges, and Dash Lightingh. Power Windows, Power Locks/Keyless, Security System, and Power Mirrorsi. Wipers, Turn Signals, Combination/Wiper Switch, Dome/Map Light, Trunk light, and Chimej. Exterior Lights
k. Cruise Controll. SRS---
18. Track Times19. Other FAQs-------------------------------------------------------------------------
Last edited by deschlong; Aug 31, 2025 at 01:25 PM. Reason: Update to Slyvania bulb guide.
Old Nov 13, 2017 | 09:38 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: FAQs - Frequently Asked (Tech) Questions
Originally Posted by CX-Adam
@Caoboy,
C-Speed changed domain names. In case you didn't find it already, the link you were looking for is now at B18C1 Motor Swap Guide - Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedR.com
Re-added 6.C.28
@Everyone: Please report in the thread if you find any issues with the FAQ.
Thank you.
Old Jul 24, 2018 | 10:05 AM
jonsey1886's Avatar
10 Year Member
Updated link for fuse 15 TSB courtesy of me:
https://drive.google.com/open?id=1KF...OrViKvNW7BkXU0
Old Jul 27, 2018 | 05:17 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Not to be rude, but please ask your question in a new thread in the actual forum. The FAQ is not a place to ask questions, more of a reference.
Old Aug 27, 2018 | 10:15 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
FYI for all new folk. Quote is dead on. Posts will be deleted without notice as "thread cleanup".
Old Aug 27, 2018 | 10:20 AM
It Wasn't Me's Avatar
... because just locking the thread is a stupid idea.
Old Aug 27, 2018 | 12:02 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Yes, it is, if you notice, there is corrections posted that I haven't updated as of yet as well as possible additions etc.
Former User
Apr 26, 2026 12:56 PM
Former User
Oct 1, 2012 11:06 AM
BOOSTED 92 SI HATCHI
Feb 10, 2006 08:28 PM
efit
Dec 12, 2004 04:26 PM
