DIY How-To: Sidemarker Install on '00 Civic Si - Honda-Tech - Honda Forum Discussion
Old 03-20-2007, 07:38 PM   #1
poison's Avatar
Default DIY How-To: Sidemarker Install on '00 Civic Si
I've had this lurking around on my computer just been too busy lately. Welp, I'm going to throw it up for you guys. If you wish to see the full picture, simply click on the picture.
First off, you will need:
- Dremel
- A piece of cardboard
- Two 8 1/2 x 11" paper
- Masking tape
- Pencil
- Two sidemarkers with wiring harness
- Patience (this task does not require a lot of time, but definitely some patience and making sure things are lined up and accurate)
<FONT SIZE="3">The car: 00 Civic Si</FONT>
Here is a picture of the fender we are first working on. You will want to clean it off and prepare for it to be modified.
Next is, place a 8 1/2 x 11" paper on the fender. The way I worked it is lining it up with the tip of the wheel well, along with the gap between the door & fender.
This helps line it up so both sides are exactly symmetrical:
Next, place the sidemarker where you want it. then trace a draft outline of where you want it.
Here is the outline drawed out:
Remove the piece of paper carefully:
Now, grab a piece of cardboard. You will use the cardboard as a practice template to make sure the sidemarker fits in perfectly to your draft drawing:
Next, cut the outline out of the cardboard template using a razor blade:
Here is a picture of the template cut out:
Place the sidemarker into the template to ensure it fits properly:
Next, put another piece of paper lined up on the car. And trace your outline of the sidemarker.
Note: For the record, you're only making one template for both sidemarkers. I've seen people do the whole thing all over again and possibly mess up. Just a mirror paper for the other side. This is the whole purpose is to keep the sidemarkers clean and symmetrical to eachother.
Your finished outline again -- but perfected:
Next, the big one:
Put some masking tape over the outline like pictured so the paper doesn't rip or go all over. And grab the dremel, and start cutting exactly how you drew it.
Note: I nor this HT take ANY responsibility if you mess up. You know how the rest goes..
Here is the piece of fender just about to be cut out:
And here is the completed hole!
Now test your fitment and boom, you're almost done!
Next is the wiring. Very simple. Depends on how you want it wired up. The Red is power, Green is accessory, and Black is ground.
If you want turn signal ONLY, you would put the two wires on Red & Black.
If you want running lights only, put on the Green & Black.
If you want both turn signal running lights, put it on the Red & Green.
Walla! And you're done.
Enjoy!
-Brandon
poison is offline   Reply With Quote
Old 03-20-2007, 07:43 PM   #2
BlueIntegraBoy's Avatar
Default Re: DIY How-To: Sidemarker Install on '00 Civic Si (poison)
Good writeup, now people can stop asking how to do this.
BlueIntegraBoy is offline   Reply With Quote
Old 03-20-2007, 07:46 PM   #3
pdiggitydogg's Avatar
Default Re: DIY How-To: Sidemarker Install on '00 Civic Si (BlueIntegraBoy)
Quote:
LOL right...
Ive been posting a link to my how-to on this for over 2 years...doesnt matter at honda-tech.
Only half the members search for anything
nice pictures btw
pdiggitydogg is offline   Reply With Quote
Old 03-20-2007, 09:15 PM   #4
Genuine Rolla's Avatar
not bad...nice right up man.
Genuine Rolla is offline   Reply With Quote
Old 03-20-2007, 09:17 PM   #5
r1whore's Avatar
yea...that was a nice write up. now all we need is one for diy on engine swaps! haha
r1whore is offline   Reply With Quote
Old 03-20-2007, 10:10 PM   #6
SoCal EJ1's Avatar
You cut the holes in the wrong spots...
SoCal EJ1 is offline   Reply With Quote
Old 03-20-2007, 10:32 PM   #7
Kafelatte's Avatar
Default Re: (SoCal EJ1)
Quote:
x2
not trying to still your tread but here's an easier way to do it. the "metal nibbler" is just a note(ignore)
&lt;center&gt;
&lt;/center&gt;
Kafelatte is offline   Reply With Quote
Old 03-21-2007, 04:06 AM   #8
poison's Avatar
Default Re: (kay20adc2)
No problem...thanks for posting the diagram to better show where to place the sidemarker..
It only helps people out more
Old 07-16-2007, 07:32 PM   #9
310HPS2k's Avatar
Default Re: (poison)
that diagram posted up there, is that an actual size template? can i just use that and trace it onto my fender? thanks
310HPS2k is offline   Reply With Quote
Old 07-16-2007, 07:47 PM   #10
CapnKrunch's Avatar
Default Re: (310HPS2k)
You don't need the harness you can wire it yourself for cheaper
My install took me a whole night with a dremel and a drill just on one (replacement) fender.. Luckily I already had the fender sidemarker hole cut when I got my car.. I used the template from my old fender's sidemarker cut to find out where to put it and all that so I wasn't hard for me at all.
The thing I hate is how everyone I see with sidemarkers on their civic or integra has them wired the rice way, with the parking lights FTL
Mine are wired the JDM way to blink with the turn signals FTW
CapnKrunch is offline   Reply With Quote
Old 07-18-2007, 12:15 AM   #11
jers99's Avatar
good write up
jers99 is offline   Reply With Quote
Old 07-18-2007, 10:00 AM   #12
KNDAFST's Avatar
Default Re: (jers99)
If anything I would suggest placing tape on the actual paint. When you go to cut your hole, the tape will prevent the Dremel from chipping the paint more then you wanted.
KNDAFST is offline   Reply With Quote
Old 03-07-2008, 01:18 PM   #13
xsk8er406's Avatar
Default Re: (KNDAFST)
sweet been looking for this
xsk8er406 is offline   Reply With Quote
Old 03-07-2008, 01:37 PM   #14
dpkelly's Avatar
Default Re: (xsk8er406)
You might also want to add RTV sealant to the hole perimiter lip. Then press in the sidemarker and wipe away any excess. This will prevent water from getting behind the sidemarker and causing rust.
Good job.
dpkelly is offline   Reply With Quote
Old 03-09-2008, 10:51 PM   #15
the_0ne's Avatar
going to do this soon!
the_0ne is offline   Reply With Quote
Old 03-10-2008, 12:18 AM   #16
teamm_AP1's Avatar
Default Re: (the_0ne)
recommend touching up the cut outs to prevent rust
teamm_AP1 is offline   Reply With Quote
Old 03-11-2008, 03:01 PM   #17
NAlover's Avatar
Default Re: (teamm_AP1)
Nice
NAlover is offline   Reply With Quote
Old 03-11-2008, 04:55 PM   #18
Agent_EM1's Avatar
Thank You. Did mine just like this, looks like I will use a dremel this time
Agent_EM1 is offline   Reply With Quote
Old 04-02-2008, 04:02 PM   #19
eastbobdam's Avatar
Hopefully this will be the year mine go in..lol. Very nerve racking operation!!!
eastbobdam is offline   Reply With Quote
Old 04-02-2008, 04:20 PM   #20
apm
Quote:
I'm worried about this too. When rolling fenders front or back the moment you have gap in the paint rust will start to creep in.
maybe rubber or some anti-rust paint?
looks good except I'm a little worried about rust as well
apm is offline   Reply With Quote
Old 04-07-2008, 06:28 AM   #21
eastbobdam's Avatar
Default Re: (apm)
Has anyone install the side markers from password JDM? I did a test template on some cardboard and the lenght of the hole seems way to small. One side has the metal clip and the other side has a small plastice tab the looks almost like a "C" shape which fits in between the fender. Just curious if anyone else has come across this........
I just ordered my radioshack nibbler so I am hoping I can find a piece of metal to make a template out of for practice.
Old 04-18-2008, 03:42 PM   #22
dohcFTW's Avatar
pics not workingg hah
dohcFTW is offline   Reply With Quote
Old 04-18-2008, 04:22 PM   #23
Agent_EM1's Avatar
Default Re: DIY How-To: Sidemarker Install on '00 Civic Si (dohcFTW)
Quote:
x2
Old 04-23-2008, 07:23 PM   #24
eastbobdam's Avatar
Default Re: (eastbobdam)
I finally did the install. It was definitely a PITA because of all the measuring from being scared of messing up. The job took me 2.5 hours for one side because of all the measurements and it started getting dark. The other side took about 1 hour with a dremel and knibbler. Word to the wise, peel the tape towards the hole, I peeled straight across and it pulled about 1 cm of paint off. I had to build it up with multiple coats. Overall, I love them and it is well worth the time and experience you gain. I would definitely to it again if need be.
Modified by eastbobdam at 7:31 PM 4/23/2008
Old 04-23-2008, 07:56 PM   #25
Neebs's Avatar
Prefer dremel than nibbler. Much cleaner.
Neebs is offline   Reply With Quote
2005 ACURA TSX RIMS AND TIRES 2005 TSX Wheels 2 03-01-2008 08:15 PM
FOR SALE: 2005 Acura TSX Rims With Tires 2005 TSX Acura TSX 8 09-05-2007 01:15 PM
A little ITR work and alot of drinking and stripers :P AssPenny Acura Integra Type-R 23 04-30-2007 10:03 PM
Fs ls vtec sandwhich made by rage Azn Batman Southern California (Sales) 3 12-19-2006 03:05 PM
What is spring surge & Why should i make sure my Valve Train is adeqauate Combustion Contraption All Motor / Naturally Aspirated 23 11-27-2006 08:59 PM
Tags
2003, 9600, civic, diy, fender, honda, install, installing, marker, si, side, sidemarker, sidemarkers, signal, template
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
