FAQ: How to change the transmission fluid in a manual D-Series Tranny (Pictures). - Honda-Tech - Honda Forum Discussion
Closed Thread
Old 10-16-2007, 08:40 PM   #1
.Ry
.Ry's Avatar
Default FAQ: How to change the transmission fluid in a manual D-Series Tranny (Pictures).
Well I kind of got back on the horse of taking care of my DD. Just got done changing the timing belt and water pump, and I felt like doing some more. This is not by any means a difficult DIY. It took me maybe thirty minutes, and I did it will hardly any tools. I have done this before so I learned shortcuts the first time. I change my transmission fluid about every 50,000 miles. It may be overkill but its so easy to do, and if it has any impact on how many miles I get out the the transmission why the hell not? This tranny is off a D16Y8 motor but I assume all D-Series trannys' will be the same or close. I used pennzoil synchromesh manual transmission fluid. Search for what you want to use, this is what I chose, and I like it. As always I am not liable for you damaging your vehicle while doing this, so lets get started.
Tools I used: 3/8" ratchet with two extensions to reach the drain bolt, and a 17mm socket to remove the fluid check bolt. Also a drain pain, and any leverage extensions you need to get the bolts off. Also a funnel, and maybe a longer tube to make it easier.
Next, jack up the car and remove the passenger side tire. Then place a drain pan under the transmission, and get ready to drain the old fluid.
The above pictures show where the drain bolt is. The first is the view from the brake rotor and the second is the up close view. Notice it takes a 3/8" drive to remove it.
Above is what I used to get that bolt removed. Two different extensions got the job done. Make sure the drain pan is underneath so you do not make a mess.
The old fluid on its way out. Once the old is out, replace the drain plug and move the drain pain over to the left to catch spillage for when you put the new fluid in. Now you can work on top of the car. You could at this point put the tire back on and drop the car down but I did not so I could take more pictures.
What the filler bolt looks like from underneath, notice just to the left of the axle.
Filler bolt from the top.
What I used to get said bolt loose. I used a 17mm socket, 3/8" ratchet, and a steel pipe, and 1/2" 10" extension for maximum leverage. She finally came loose.
Now its time to hook up the funnel to easily get the new fluid in. First three are from the top, the fourth is from the bottom. You can also use a clean rubber hose for a longer and easier reach but I misplaced mine.
Once the funnel tube is in the hole go ahead and pour in the new fluid. Pictures show just that. You know the tranny case is full when the new fluid starts to come out. Do not put the bolt in until the car is level or off the jacks so you know for sure the fluid level is right. Once you have done this go ahead and put the bolt back in
Filler/ Fluid Check bolt back in and tightened. Go ahead and clean off any spilled fluid. Empty the old fluid into a disposal can.
Tighten/Torque your lug nuts, and go out for a drive. If you have not changed the fluid in a long time you may feel a difference.
***Just a reminder the final check for the correct fluid level is when the car is on a level surface. If the transmission is at an angle you will not have enough fluid.
***Also, check for any metal shavings throughout this process, if you find some time to do some research.
I hope this helps anyone who has not done this. I probably took to many pictures, but I like them when I do my DIY jobs so I did it here. Feel free to add comments, concerns, or add additional information.
.Ry is offline
Old 10-16-2007, 08:49 PM   #2
DCSportEJ1Civic's Avatar
Default Re: FAQ: How to change the transmission fluid in a manual D-Series Tranny (Pictures). (.Ry)
nice write up. i used that same funnel to fill my tranny. removing the tire is unnecessary tho imo. i used honda mtf too. im not a fan of synchromesh but im sure it works fine.
DCSportEJ1Civic is offline
Old 10-16-2007, 09:03 PM   #3
.Ry
.Ry's Avatar
Default Re: FAQ: How to change the transmission fluid in a manual D-Series Tranny (DCSportEJ1Civic)
I took the tire off so I did not have to get under the car because I did not use jacks, and I wanted to take pictures. Thanks though for the !!
.Ry is offline
Old 10-16-2007, 09:08 PM   #4
Default Re: FAQ: How to change the transmission fluid in a manual D-Series Tranny (.Ry)
ah ic. im sure the pics were easier to take with out the tire there too lol. sorry if i sounded like i was criticizing you. i didnt mean it like that.
Old 10-16-2007, 09:16 PM   #5
.Ry
.Ry's Avatar
Quote:
None taken my friend!
.Ry is offline
Old 10-16-2007, 09:27 PM   #6
95ProjectEJ1's Avatar
Good stuff. Very easy for anyone to do if they are skeptical about doing it themselves
95ProjectEJ1 is offline
Old 10-16-2007, 10:12 PM   #7
EJ8 944's Avatar
Default Re: FAQ: How to change the transmission fluid in a manual D-Series Tranny (95ProjectEJ1)
nice write up, i was going to change mine when i change my oil this weekend, this comes in handy i guess
EJ8 944 is offline
Old 10-16-2007, 10:28 PM   #8
Ex-Eg-Driver's Avatar
P.I.M.P!
Ex-Eg-Driver is offline
Old 10-16-2007, 10:31 PM   #9
MEAT PATTY
Default Re: FAQ: How to change the transmission fluid in a manual D-Series Tranny (JayKayNidas)
Nice, write up. I don't bother removing the plug any more to fill the tranny back up. It just makes a mess, so I remove the vehicle speed sensor and fill it from their.
goforbroke is offline
Old 10-17-2007, 08:32 AM   #10
.Ry
.Ry's Avatar
Default Re: FAQ: How to change the transmission fluid in a manual D-Series Tranny (goforbroke)
Quote:
Ah damnit, I forgot that you could fill it back up this way. I just would worry that some people would not do their homework, and put way to much fluid back in.
Thanks for the comments!!
.Ry is offline
Old 10-17-2007, 09:29 AM   #11
themikewoo's Avatar
Nice write up. Should be put in the FAQ list.
themikewoo is offline
Old 10-17-2007, 10:08 PM   #12
.Ry
.Ry's Avatar
Default Re: (themikewoo)
Quote:
Done, thanks!
.Ry is offline
Old 10-17-2007, 10:11 PM   #13
bmoua's Avatar
same goes here
bmoua is offline
Old 11-13-2007, 06:43 PM   #14
hatch_'s Avatar
awesome write up, im doing this tomorrow.
hatch_ is offline
Old 12-01-2007, 02:17 AM   #15
tonychony's Avatar
Default Re: (hatch_)
i was wondering because i just purchased some blox magnetic plugs for my tranny and oil pan. i dont get why the tranny magnetic plug would be at the top and not at the bottom of the tranny where the drain plug is. the point of having magnetic plugs is to get all the metal shavings out but wouldnt they sink to the bottom?
tonychony is offline
Old 12-01-2007, 02:19 AM   #16
tonychony's Avatar
Default Re: (tonychony)
oh yeah also where is the vehicle speed sensor? dont wanna make a mess. also if i go from the vss how can i tell if its full if i dont take out the level plug?? certain amount?
thanks
Old 12-01-2007, 02:55 AM   #17
all_conference's Avatar
where is the vehicle speed sensor located? picture would be greatly appreciated...thanks
all_conference is offline
Old 12-11-2007, 07:43 PM   #18
mahler29's Avatar
Also, if you refill from the speedsensor, you can add an additional quart. My freinds dad works on the Honda Race Team, he builds there trannies. He was the person that told me this was a good idea. Just make sure that if you get your eng oil changed at a shop like Jiffy lube or where every, make sure you tell them not to remove the check plug on the trans. Otherwise they will be in for a surprise. Anyways, I have been running my EJ1 like this for 200k miles now and haven't had any problems. That and I only use the honda man trans fluid.
mahler29 is offline
Old 12-11-2007, 07:57 PM   #19
JDM_King's Avatar
Good write up, now I gotta go do mine. lolz
JDM_King is offline
Old 12-11-2007, 08:41 PM   #20
SpeedoKing's Avatar
Default Re: (JDM_King)
Amazing wright up i have a y8 too and have wanted to do this for a while now i think ill get off my lazy *** and do it hahaha
SpeedoKing is offline
Old 12-26-2007, 01:16 AM   #21
MilanoCpe's Avatar
Default Re: (SpeedoKing)
man, this is really helpful
thx alot for doing the writeup
MilanoCpe is offline
Old 01-29-2008, 02:53 AM   #22
jinotiq's Avatar
im replacing mine tommorrow, or technically today. THANKS$#^@
jinotiq is offline
Old 01-29-2008, 03:21 AM   #23
bmoua's Avatar
bmoua is offline
Old 01-29-2008, 05:56 AM   #24
96hb's Avatar
Default Re: FAQ: How to change the transmission fluid in a manual D-Series Tranny (bmoua)
Great write up! I've been needing to do this. I haven't changed my tranny fluid in 4 years.
96hb is offline
Old 02-09-2008, 05:00 PM   #25
fogelsong's Avatar
Thanks for the write-up! I drained and filled with Honda MTF this afternoon and I can tell a difference.
fogelsong is offline
Closed Thread
Default [FAQ] How-To: Change your Civic Manual Transmission Fluid imadigitalgod Honda Civic / Del Sol (1992 - 2000) 187 04-23-2016 08:08 AM
HOW TO: My auto to manual swap PICS! 56k no no. ejoner Honda Civic / Del Sol (1992 - 2000) 198 01-29-2016 04:24 PM
-->COMPLETE How-To:: Turbocharge Your Honda // Rep-ing Hypnotik Speed Emshhh Forced Induction 559 07-29-2015 02:08 PM
Changing the tranny fluid on a eg civic Andrew14 Honda Civic / Del Sol (1992 - 2000) 21 06-28-2010 02:12 PM
Chronicsinners / BobFab 1990 Civic HB Build Thread - Old and new pics Chronicsinners Appearance Build Threads 30 02-05-2010 03:36 PM
Tags
92, 96, 99, change, civic, del, filling, fluid, honda, manual, picture, point, series, sol, tl, tranny, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
