Short Shifter Install in an 00 SI - Honda-Tech - Honda Forum Discussion
Old 01-25-2004, 12:12 PM   #1
Ricey McRicerton's Avatar
Default Short Shifter Install in an 00 SI
I know this is fairly straightforward, but I put in my first short shifter yesterday. I don't have any pictures, so sorry gentelmen. I don't have a digicam. The instructions that came with the B&M shifter were vague to me, and these may not help any, but here goes.
First you need to jack the car up. After you do that put jackstands under the car so it does'nt fall on you!!
Next you need to unbolt the shift linkage. The bolt is a 14mm head, and the nut is a 12mm head. Drop the shift linkage down. I put it twoards the drivers side of the car, as the exhaust on the car I was working on did'nt let it fall on the other side.
Now you need to unbolt the 2 bolts that hold the stabilizer to the car (both 12mm heads). I had to pull off the actual rubber part that bolts the car to get to the next set of bolts, which was the only part that was difficult at all. There are 2 bolts that hold the shifter up now. Those were the most difficult for me, as the bolts were seized and getting a hold of the back of the bolt is a b!tch!! They're almost round, with 2 flatened sides, and you can't see what you're doing. You can use a 12mm wrench to hold the back of the bolts and get them off. Now the shifter should slide right out. Now you need to strip down the shifter that just came out of the car and relocate the things onto the new shifter.
Getting it back in is just a reversal of these steps. Just make sure you have the shifter facing the right direction before you bolt it back to the linkage!!
Ricey McRicerton is offline   Reply With Quote
Old 07-15-2004, 11:10 PM   #2
EJ8 GSR-T's Avatar
Default Re: Short Shifter Install in an 00 SI (Ricey McRicerton)
anyone have pics of how to intsall short shifter on a 98 ex?
EJ8 GSR-T is offline   Reply With Quote
Old 03-09-2009, 04:18 PM   #3
Quote:
you cant read?
its fairly simple design. shouldnt be too hard to install. i did mine in 15 mins.
dame-ningen is offline   Reply With Quote
How to: Auto to 5spd Swap **lots of pics** s.cali alan Honda Accord (1990 - 2002) 154 12-26-2016 04:57 PM
How-To: 5th gen accord clutch install h22a2JZGTE Honda Accord (1990 - 2002) 21 05-26-2016 11:36 AM
[FAQ] Skunk2 short shifter install on 93 Civic CX 56k no way TeStUdO Honda Civic / Del Sol (1992 - 2000) 21 07-21-2006 07:43 PM
Review: Fastline performance shifter and a few photos. null. Honda / Acura 58 11-13-2005 08:30 PM
Energy shift bushings install notes... Chairman Kaga Acura Integra 3 10-08-2001 06:46 AM
Tags
00, 92, 96, accord, civic, del, honda, install, installation, linkage, pics, put, shift, shifter, short, sol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
