1995 Civic EX ABS Cel
Old Feb 13, 2011 | 05:17 PM
SIDreamer's Avatar
Icon3 1995 Civic EX ABS Cel
Hello guys today I did my suspension swap for my 1995. From Oem, to Tein Super Street. I did everything I remember correctly and what not. When I finished the swap my ABS light was turned on????? -_- Any hints on what this could be if any one has had it happened to them. It is in my 1995 Civic Sedan EX. Thanks YOU
Old Feb 13, 2011 | 05:24 PM
civicsmoke's Avatar
Default Re: 1995 Civic EX ABS Cell
Start off with checking and cleaning your abs sensor, wildoutgsr did a nice write up for you to follow.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-%2A%2A%2A-check-clean-your-rear-abs-wheel-sensor-2205909/
Old Feb 13, 2011 | 05:28 PM
Former User's Avatar
Jump the service connector to pull the ABS code. The ABS light will blink the code(s), just like pulling CEL codes.
Old Feb 13, 2011 | 05:31 PM
SIDreamer's Avatar
My bad for not knowing but where is the service connector
Old Feb 13, 2011 | 05:39 PM
As shown in the diagram and also in the CEL sticky at the top, the service connector is located above the ECU behind the passenger kick panel.
Old Feb 13, 2011 | 05:58 PM
SIDreamer's Avatar
Ok cool I will try that, I just went for a ride and when I start the car, the ABS light truns on and goes away. After I start driving after about 20 seconds it truns on. That usually is a sign of? Also do abs lights turn on if any wheel is loose?
Old Feb 13, 2011 | 05:59 PM
Don't guess what the problem might be -- just pull the code.
Old Feb 13, 2011 | 06:15 PM
SIDreamer's Avatar
I used to use a paper clip to get codes I dont have a jumper harness can I do the same thing with this?
Old Feb 14, 2011 | 05:52 AM
SIDreamer's Avatar
4-2 Circuit of left hand front wheel speed sensor
Thats is the Code that it gave me any ideas? When I was putting the suspension on I pulled the brake and heard a cable pop I was like OOOO lol but when I took a look it was just a rubber part that had broke didnt seem important. I dont know if that has anything to do with it. Thank You.
Old Feb 14, 2011 | 07:04 AM
Inspect the speed sensor and its wire for that wheel:
Old Feb 14, 2011 | 09:03 AM
SIDreamer's Avatar
I inspected the sensor and wire, and they seemed to be in really good shape. I am going to try and clean it, but if that does not work I dont think i want to spend that much money on a new speed sensor. Is it worth to just get that off.
Old Feb 14, 2011 | 09:23 AM
Pull out your trusty multimeter:
Old Feb 14, 2011 | 09:43 AM
SIDreamer's Avatar
Guess I have to go buy one lol
Old Feb 14, 2011 | 12:30 PM
SIDreamer's Avatar
Today I will be going to get it tested.... I remember pulling the whole brake system and hearing something pop. No lines broke but I know it came from the ABS like in the Front Driver, on the side im getting code. Could that have created a short in the system? What gets me is that nothing seems broken and I inspected it today. The front sensors should be cleanred as well correct?
Old Feb 14, 2011 | 09:09 PM
SIDreamer's Avatar
Hey question, I was looking today at wheel speed sensor and I noticed they come with the wire that connects them. That same wire was the one that I pulled and hear a loud pop. My assumption is I caused a short in that wire causing that whole sensor to messed up could I be correct?
Old Feb 16, 2012 | 03:43 AM
stackz's Avatar
at the jetties fishin'
Community Builder
up from the dead.
is there a list of abs codes anywhere? just like the CEL, a long flash is a "10" and short flashes are 1-9 right?
Old Feb 16, 2012 | 04:34 AM
The code list is in the diagram right above your text. Also see post #3.
Old Feb 16, 2012 | 07:27 PM
vwjimmy's Avatar
You probably tore the wiring to the sensor. Remove the covering and inspect the wires...especially near the end and at where the tug happened.
jrmullins85
Sep 24, 2015 05:40 AM
lovelove
Suspension & Brakes
Feb 11, 2013 03:04 PM
hondacivic94exvtec
Jul 9, 2007 09:39 AM
LS1powered
Apr 27, 2006 09:13 PM
SlammedCD7
Nov 9, 2004 03:56 AM
