Quick Check Engine Compression ratios - Honda-Tech - Honda Forum Discussion
Old 11-19-2003, 03:26 AM   #1
ace1875's Avatar
Default Quick Check Engine Compression ratios
The Calculation of an engine's compression ratio ( C.R. ) is based on the formula :
SV= Swept Volume for one cylinder in CC's= Bore x Bore x stroke x 12.9
CV= Clearence Volume for one cylinder in CC's= HV minus EDV plus DV plus GV
HV= Head Volume (measured in CC's)= Best if measured because head volume vaires
EDV= Effective Dome Volume (measured in CC's)= Dome volume minus valve relief and/or dish volume
DV= Deck Volume clearance (piston to deck) (measured in CC's) = Bore x Bore x Deck Height x 12.9
GV= Gasket Volume (measured in CC's)= Gasket Bore x Gasket Bore x Compression Thickness x (12.9 or enter known gasket volume)
edit: Cubic Inch Displacement measurement
Bore x Bore x stroke x .7854 x 4(cylinders)
Thought this should be in H-T to be archived if someone needs these formulas. If anyone have anymore usefull formulas please feel free to post them.
ace1875 is offline   Reply With Quote
CR Calculations and Compression Testing flyrod Honda Prelude 16 10-29-2010 06:55 AM
H23Vtec fully built 600hp+ ready, Endyn,Golden Eagle, ... ludesleep Classifieds: Forced Induction 6 12-03-2009 12:22 PM
chamber cc's measured.... wtf???!!!! 3.504 Tech / Misc 1 06-22-2005 11:17 PM
Decking head vs compression. Check my math. Blaise All Motor / Naturally Aspirated 2 10-17-2004 05:54 AM
Some interesting formulas a few of you might like... vtecvoodoo Acura Integra Type-R 6 06-27-2002 07:59 PM
check, checking, commpression, compression, compressions, del, engine, honda, list, motor, odyssey, prelude, preude, ratio, ratios, sol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
