How to make the Door Ajar Light in your USDM cluster work
There's already one on the internet which says that you "need" a ctr gauge bezel for this to work. Well, you don't. This option was included in Japan and Europe but in the US it was optional and seen as luxury. That's why this was not included standard. THIS WILL ONLY WORK ON US MODELS. In Canada, it IS possible but you'll lose a funtion from your guage cluster.
Again, take out the cluster and take apart and look @ the following.
The red circle is where we are going to put it.
Notice the two holes. Those are put there by the factory and we going to join them using a diode.
heres the back view
again, using the method in this thread, we sand this area off from the back and use a paper taped over a colored cd case to make our symbol.
here's the link to the picture of the open door you can use.
this is how it should look afterwards
then, look under the steering wheels and you'll see something like this.
splice into the Light Green/Red wire and run it up to the cluster like shown
We want to cut that pink wire out from the cluster harness that is on the left. THIS IS WHY IT WONT WORK IN CANADA BUT ONLY IN THE USA. In Canada, that pink wire is actually used for something. In the USA, that is just a dummy wire.
Now, put that pink wire into the first hole on the center blue cluster. Then, attach that extension from the light green/Red wire to this.
Use a factory bulb pn# 35505-sa5-003 and plug in into the open hole behind that opening.
Voila you are done.
Modified by ludakrishna420 at 10:53 PM 3/24/2008
heres the back view
Voila you are done.
Oh look, I can change this
Re: How to: Door Ajar Light
^ Yes.
And ... for the record, in Canada the PNK wire is for the low washer-fluid sensor... but what I don't get is that that indicator light is supposed to be on the far left of the cluster - not in the same spot as the door open indicator.
Re: How to make the Door Ajar Light in your USDM cluster work
I know this thread is coming back from the dead. But I am in the middle of doing this project and was wondering which exact diode must be used for this? I bought 200v-1amp silicon diode at radio shack and was not sure its the right one or I need something a little bigger with more voltages?
how would you make this work in a gsr cluster just by splicing the wire?? that is what i am assuming it just a messy diy
blackdx1
01-25-2011 04:47 PM
ninety9ex
07-09-2003 06:36 PM
