[FAQ] How to get the SRS light into JDM clusters. Air bags not working w/ JDM cluster? Click me. - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page > [FAQ] How to get the SRS light into JDM clusters. Air bags not working w/ JDM cluster? Click me.
Old 07-19-2007, 07:37 PM
FalkenSiR's Avatar
Default [FAQ] How to get the SRS light into JDM clusters. Air bags not working w/ JDM cluster? Click me.
So I had some files in my computer with some useful info.
Thought I'd spread it out to clear things up a bit. This is for 92-95 civics.
Originally Posted by random info
A few people told me the airbags wouldn't work, (after JDM cluster) so here is what I did on my jdm cluster about a week ago. Take the US cluster and remove the clear plastic cover. Then unscrew the speedometer from the back via three small screws.
The gauge will come right out, so set it aside and then remove the temp gauge/tach (depending on model) which is to the left of the cluster, it has the same type of screws in the back. Now that the gauge/tach are out of the way, the SRS connector is held in with a little clip in the back so pop it out. You can then put the SRS connector into the jdm cluster by using the same method.
I disconnected the battery to be safe then removed the jdm cluster. Remove the gauges and the srs will clip right into the jdm cluster. Then after you put the gauges back in you can either use the clear plastic off of the usdm clsuter so that the light will shine through or u can cut the hole in the jdm bezel and swap over the SRS light cover. Personally, I just cut a hole where the light is so that I can still see it come on and off when i turn the car on even though it doesn't say SRS, I still know what the light is for.
Now you can plug in the yellow plug and have your airbags working again. The same thing can be done for the cruise control but I don't have CC so I didn't worry about it. Sorry I didn't take any pics but I hope this helps
Edited for spelling/grammar.
Modified by FalkenSiR at 11:55 AM 7/20/2007
FalkenSiR is offline
Old 07-19-2007, 07:54 PM
* B A N N E D *
i did'nt know it was possible.
akunamatta is offline
Old 07-19-2007, 08:25 PM
FalkenSiR's Avatar
Default Re: (akunamatta)
It is
Now, something I don't know for a fact is if the SRS system doesn't work with the JDM clusters. As stated above, some people's cars apparently didn't. Technically, there is an open in the SRS system if the plug is unplugged (like most of us), so in theory, it shouldn't work. Scary.
Safety first.
Old 07-19-2007, 08:27 PM
* B A N N E D *
Default Re: (FalkenSiR)
Originally Posted by FalkenSiR
Now, something I don't know for a fact is if the SRS system doesn't work with the JDM clusters. As stated above, some people's cars apparently didn't. Technically, there is an open in the SRS system if the plug is unplugged (like most of us) so in theory, it shouldn't work. Scary.
Safety first.
??????? hard to read
Old 07-19-2007, 08:31 PM
FalkenSiR's Avatar
There, I added a comma.
Old 07-20-2007, 10:55 AM
FalkenSiR's Avatar
Default Re: [FAQ] How to get the SRS light into JDM clusters. Air bags not working w/ JDM cluster? Click me.
just a bump before being archived
Old 08-03-2007, 11:40 AM
typer ej's Avatar
how do i get the srs light in a 97 itr guage bezel? i cant figure that one out
typer ej is offline
Old 08-14-2007, 07:46 AM
FalkenSiR's Avatar
ITRs are not my thing BUT if the USDM SRS light fits into the JDM cluster, then follow the steps above.
Old 05-05-2009, 09:16 AM
joezjdm4dr's Avatar
good stuff....
joezjdm4dr is offline
joezjdm4dr's Avatar
a falken where you at?
Old 05-05-2009, 09:17 AM
joezjdm4dr's Avatar
get another 4 dr yo...
GRN-BNDT
03-28-2016 10:09 PM
BlueIntegraBoy
351
12-29-2015 08:32 AM
edzz10
Odyssey | Ridgeline | MDX | Pilot | RDX | HR-V
06-21-2011 06:55 AM
redline870
10-13-2008 04:01 AM
stockegsix
12-04-2003 08:27 AM
  • Ask a Question
Question Title:
Description:
