[FAQ] Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch!
First remove your backseat: Click Here.
Tools Required: 10mm. socket, 17mm. socket, standard phillips head screwdriver, bigger phillips head screwdriver, a ratchet, and one wide and one thin flathead screwdriver.
Total Time: ~ 1.5 Hours.
<FONT COLOR="red"><FONT SIZE="3">How-To Remove Right Rear Quarter Trim Panel:</FONT></FONT>
STEP 1: Remove the trim piece which is directly below the hatch gate. Gently & slowly pull the rear trim piece outwards. There are 2 clips located on the left and right side behind the trim piece.
Next, starting on the top of the trim piece, and working from the outer edge to the center... gently & slowly pull the trim piece upwards.
There are 4 clips on top holding the trim piece onto the chassis.
STEP 2: Remove all the bolts/screws that are holding in the right rear quarter panel.
#1: Use your "bigger phillips head screwdriver" and unscrew the plastic "L" shaped bracket from the rear quarter panel.
#2 & #3: Use your 10mm. socket & ratchet to remove these bolts from the rear quarter panel.
#4: Use your "standard phillips head screwdriver" to remove this plastic grommet from the rear quarter panel.
#5 & #6: Use your "standard phillips head screwdriver" to remove these plastic grommets from the rear quarter panel.
#7: Use your "standard phillips head screwdriver" to remove this screw from the rear quarter panel.
#8: Use your "wide flathead screwdriver" to pry out the speaker lid.
The screw is behind the speaker lid.
Use your "bigger phillips head screwdriver" and unscrew this screw from the rear quarter panel.
Next slip off the rubber seal from around the backseat striker. (Don't mind the screwdriver).
Use your 17mm. socket and ratchet to remove this seat belt anchor bolt from the chassis.
STEP 3: Starting from the front and moving your way to the back, pull off the right rear quarter trim panel. Take your time... I bent several clips by becoming inpatient and frustrated.
Slowly pull the rear quarter panel outwards from the door opening.
There are 3 clips on the inside of the rear quarter panel. They snap into the chassis, you can see there locations below.
From the back of the rear quarter panel, start to pull the panel outwards.
Below the rear pillar trim panel are 2 clips that are on the inside of the rear quarter panel. I found these to be the most stubborn and difficult clips to get out. Take it slow!
Here you can see where the 2 clips join into the rear pillar trim panel. Pull the rear quarter panel outwards.
Right rear quarter trim panel removed!
STEP 4: Remove the rear speaker bracket and the backseat striker.
#1, #2, and #3: Use your 10mm. socket & ratchet to remove these bolts from the chassis.
<FONT COLOR="red"><FONT SIZE="3">How-To Remove Left Rear Quarter Trim Panel:</FONT></FONT>
[STEP 1:[/b] Remove all the bolts/screws that are holding in the left rear quarter panel.
#2: Use your 10mm. socket & ratchet to remove this bolt from the rear quarter panel.
#3: Use your "thin flathead screwdriver" to pry open this screw cover.
#4, #5, and #6: Use your "standard phillips head screwdriver" to remove these plastic grommets from the rear quarter panel.
Close-up pic.
STEP 3: Starting from the front and moving your way to the back, pull off the left rear quarter trim panel. Take your time... I bent several clips by becoming inpatient and frustrated.
Close-up pic.
AFTER PICS:
WEIGHT SAVINGS:
Both rear quarter trim panels:
Weight: ~ 10 lbs.
TOTAL WEIGHT SAVINGS: ~ 10 lbs.
Conclusion: Yes i know most of you will think spending this much time to save only 10 lbs. isn't worth it, but i had nothing better to do, and i like working on my car, so... TO EACH HIS OWN!!!
If you have any questions feel free to PM me.
<FONT SIZE="2"><FONT COLOR="red">Front and Rear Pillar Trim Panel / Headliner Removal Coming Soon!!!</FONT></FONT>
Modified by VX at 5:07 PM 11/30/2003
Close-up pic.
Close-up pic.
AFTER PICS:
WEIGHT SAVINGS:
Weight: ~ 10 lbs.
Re: [FAQ] Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch! (VX)
excellent man!!!!
i saved it before all the clutter comes in.
Since you removed are going to sell your panels?
Edit: Didn't wanted to sound like a Vulture
Modified by ace1875 at 6:21 AM 11/28/2003
Re: [FAQ] Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch! (ace1875)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ace1875 »</TD></TR><TR><TD CLASS="quote">excellent man!!!!
Since you removed are going to sell your panels?</TD></TR></TABLE>
Thank you. Yes I will be selling my carpet/backseat/interior panels (headliner/rear quarter trim panels etc.)
When i'm ready to sell them, and take pics of them, i will post them in my forsale thread... so please no offers on the interior stuff yet... let's not get O.T. here.
Thanks for the compliments. Good night guys. Turkey tryptophan is owning me.
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX »</TD></TR><TR><TD CLASS="quote">. Total Time: ~ 1.5 Hours.
lol... it would have taken me about 1/2 hour to remove the panels, but about 6 months to take the pics, write on them and then post about it.... seriously, goodwriteup for those who are mechanically challenged
Re: [FAQ] Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch! (rodney)
Haha, thanks. Yes ALL of my how-to's do take me longer, b/c i'm learning as i go. Plus all the pics, and angles and stuff do slow me down. I had to back track quite a bit to get some shots.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX »</TD></TR><TR><TD CLASS="quote"><FONT SIZE="2"><FONT COLOR="red">Front and Rear Pillar Trim Panel / Headliner Removal Coming Soon!!!</FONT></FONT></TD></TR></TABLE>
Now Posted! Click Here!
One thing to keep in mind, be very careful of the metal that becomes exposed in the door frame. IT IS VERY SHARP and I should know since I cut my hand pretty bad on it.
Re: (htcsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by htcsi »</TD></TR><TR><TD CLASS="quote">but isnt that ~10 lbs including the 3 cans and the wood platform?</TD></TR></TABLE>
Nope. I calibrated the scale w/ the cans and wood on it.
Re: (Bunz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunz »</TD></TR><TR><TD CLASS="quote">nice im not gonna do that make my car look ugly</TD></TR></TABLE>
That's great!!! Now go share your cookie with this guy:
Re: [FAQ] Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch! (sshaikh01)
Damn....I was hoping for a faq on how to get my window trim off, or
more like back on. Wish I knew that you have to take out the rear
quarter panel windows to put the trim on........baauh.
Re: [FAQ] Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch! (elwood)
This helps me emensely as I gutted the car out about two years ago. Now I know what fasteners I need to put in my new and improved interior panels
Should make a good write up of my own on my new project since there are no install pictures anywhere on the net. JDM EG6 install coming soon
Re: [FAQ] Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch! (White Lightnin)
VX is the writeup gran-master
The title of the thread caught me off guard too. Not used to people using the correct chassis code for USDM's.
Re: [FAQ] Detailed How To: Remove Rear Quarter Trim Panels From An EH Hatch! (boostsohfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostsohfast »</TD></TR><TR><TD CLASS="quote">VX is the writeup gran-master
The title of the thread caught me off guard too. Not used to people using the correct chassis code for USDM's. </TD></TR></TABLE>
Thanks bro, i appreciate it!!!
Yeah i don't really like using the incorrect lingo, even if one term is more commonly used or what not. I don't drive an EG, and never will.
