96-00 Trunk Board Dimensions
Old Oct 27, 2008 | 09:36 AM
Varao's Avatar
Default 96-00 Trunk Board Dimensions
I recently bought a EM1 but there was no trunk board at all. I was curious if there was a set of dimensions out there so I can make one? I did a search and nothing came up. Any and all help is greatly appreciated thanks!
Old Oct 27, 2008 | 01:11 PM
Varao's Avatar
Default Re: 96-00 Trunk Board Dimensions (Varao)
Bump
Old Oct 27, 2008 | 03:15 PM
itsmejto's Avatar
find another guy who has same car, draw round it onto a sheet of cardboard then you have a template to cut yours to.
Old Oct 28, 2008 | 09:57 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
It's kind of a weird shape. Not really square.
Okay, I finally got everything together.
This is a photo of the trunk board out of my '98 Civic coupe. They should all be the same. I imagine this would fit sedans too, and the rear half can be trimmed to fit a hatch. Just don't forget the handle hole at the bottom.
Old Oct 29, 2008 | 08:33 AM
Varao's Avatar
Default Re: FV-QR (NOFX)
Thank you so much man you are a life saver!! Really good info I wish it could get into the FAQs section!
Old Oct 29, 2008 | 10:07 AM
Davus's Avatar
Default Re: FV-QR (Varao)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Varao &raquo;</TD></TR><TR><TD CLASS="quote">Thank you so much man you are a life saver!! Really good info I wish it could get into the FAQs section!</TD></TR></TABLE>
Lol.
Anyway, I re-traced mine onto some 1/4 plywood once, good to have the dimensions finally available though.
Old Oct 29, 2008 | 12:35 PM
NOFX's Avatar
H-T White Ops
Default FV-QR
Glad to help.
As far as FAQ threads, just mention it to Syndacate (OP of the FAQ) and see if he wants to add it or not.
Old Apr 27, 2009 | 10:46 PM
tontonpacute's Avatar
where'd the pic go?
Old Apr 27, 2009 | 11:01 PM
KillBot's Avatar
You could just buy one for $50
http://www.hondaautomotiveparts.com/...gry5=FLOOR+MAT
Old Apr 28, 2009 | 05:31 AM
thumper64's Avatar
Or, he could buy or obtain a piece of 1/4in plywood and make one for much less and use the rest to buy candy and porno.
Old May 1, 2009 | 10:56 AM
KillBot's Avatar
Assuming he has, or can borrow a jig saw...then it would be much less, weigh more and look a little off.
Old Jul 30, 2011 | 03:29 PM
Cunninga's Avatar
Or, you could buy a template off of eBay and make the cover out of high density board.
http://shop.ebay.com/&Civic+spare+tire+cover+template
Old Jul 30, 2011 | 03:57 PM
grumblemarc's Avatar
The Grumpiest
Or...you could not bump old threads.
Old Feb 5, 2014 | 08:19 AM
asilva732's Avatar
Default Re: FV-QR
Hey any chance you still have the photo/dimensions available?
The link is no longer working for me. Thanks!
Old Feb 5, 2014 | 09:00 AM
J...H22's Avatar
I've got a trunk floor I'm going to build once I get this heater issue fixed. I did get approx build measurements though. Hope this helps.
36'w x 8'-10' d
47'w
57'w
total length/depth 44'
Old Feb 8, 2014 | 01:14 PM
asilva732's Avatar
36'w x 8'-10' d
47'w
57'w
I appreciate the help, but I am quite not following. I will see if I can recreate a picture with similar to the one above.
And what would be the name of the material that makes up the board to purchase?
Old Feb 8, 2014 | 07:23 PM
J...H22's Avatar
I gave the approx dimensions for a floor panel. If you were to cover the floor, that's a ballpark set of measurements for what it would be, though not including a cut out for the spare tire. I'm using mdf, you would be good with 1/2' or 3/4'. I would advise spraying the bottom,as in the side that rests on the floor, with rubber undercoat. This is in case you develop a leak in the metal floor itself. It'll keep your floor board from rotting out faster.
Old Feb 8, 2014 | 07:27 PM
NotARaCist's Avatar
I never narc'd on nobody!
When I replaced mine, I bought a special kind of board from Lowes. It's made to go behind the tiles in bathrooms, so it's mold and mildew proof. Very easy to cut and work with, but it also supported my old JL 10W7-HO just fine...and anyone who has carried one of those knows it's heavy as a ************. Definitely the material I recommend for replacing the trunk board.
Old Feb 8, 2014 | 08:25 PM
crazyhouse2011's Avatar
Old Feb 9, 2014 | 04:24 PM
NOFX's Avatar
H-T White Ops
Default Re: FV-QR
Why pay for it when the information is free here?
The photo is in the post you quoted. It works for me. Maybe try clearing cookies? Not sure why imageshack won't work for you.
Old Feb 10, 2014 | 03:58 AM
asilva732's Avatar
Default Re: FV-QR
Hi,
From my end I can see the thumbnail of the photo that is in your post.
But when I click on this thumbnail, it sends me to the imageshack website and says the image is no longer available.
Old Feb 10, 2014 | 05:38 AM
You do realize that by now you could have just taken a piece of paper and a tape measure and figured out the dimensions yourself?
Old Feb 12, 2014 | 06:20 PM
NOFX's Avatar
H-T White Ops
Default Re: FV-QR
Hi,
It's definitely still there. Try clearing your cookies. I had never viewed that image on this device and it loaded fine for me.
Here it is rehosted. Not sure why you couldn't get it to load.
http://imgur.com/ZrHqyEE
Ep1dem1c
Jul 21, 2012 06:29 PM
siblue_gzer
Apr 28, 2008 12:06 PM
aznguy0087
Sep 27, 2007 05:09 PM
WhtHatchBack
Jan 31, 2006 10:57 PM
dextR
Feb 23, 2004 06:54 PM
