DIY: Civic/del Sol/Integra distributor O ring replacement - Honda-Tech - Honda Forum Discussion
Old 10-14-2011, 03:53 PM   #1
mac_24_seven's Avatar
Default DIY: Civic/del Sol/Integra distributor O ring replacement
*** When I was looking for a part number for the O ring for my del Sol, I came across the thread in the FAQ, but the pictures don't show up. So here's another write up with part numbers/pics that can be used in place of the old/non pic working thread.
:D***
Distributor O ring replacement
You may ask yourself: Mac, how do I know if I need to replace my dizzy O ring? If your engine has more oil outside than it does inside and its leaking on the tranny, it probably needs replaced.
After driving 80 MPH on the interstate, when I would get to my destination smoke would be coming from the hood as the oil was ending up on the exhaust. NO bueno. One woman said my car was on fire. Funny story as she was pretty stupid and was convinced my car was going to catch on fire. But anyway... It was leaking. Feast your eyes upon thy picture!
Tools needed:
- 12 mm Socket/extension/ratchet
- 12mm wrench (optional if you don't have a ratchet)
- Small flat head screw driver/small knife or pick to get O ring off/on.
- Nerves of steel and wits like razor blades.
Time needed:
- 20 mins or so
Parts needed:
- Distributor O ring
- Rags (for greasy hands)
- Honda part # 30110-PA1-732 Size: 26.4x3.1mm
- Napa part #/size 25.2x8
Cost:
- OEM $14.24 shipped from Majestic Honda (may be cheaper at your local stealership)
- $10.00 from eBay
- $1.25 from Napa.
** Note** I used an O ring from Napa. It was slightly smaller than the OEM but seems to work just fine. Not to mention it was much cheaper.
From Majestic Honda's website.
Time to get dirty!
Step 1: Find your car and gather your tools/parts. Don't do like I did and not let your car cool off before you do this. The engine is rather hot :and flesh burns easily.
le tools
le engine... Shes dirty, I know. But no dirtier than your mom so its ok 252,000 miles and still going strong!
Step 2: Scribe a mark on the dizzy so you know where your timing needs to be set. Make it look like so. Use a screwdriver or teeth if you must, as long as its sharp and can make a mark in the metal.
Step 3: Remove the (3) 12mm bolts holding the distributor on. **Note** You can use a wrench, but a ratchet/extension is much easier.
I removed the bolts already in this pic, but they are each on one of the three ears. If you can't find the bolts, you probably don't need to attempt replacing the O ring in the first place.
Step 4: Gently pull on the distributor and it'll pop out of place. Ta daa!!
**Note** I didnt have enough room to remove the O ring with the spark plug wires still connected, so I just pulled em off the spark plugs. My wires are staggered in length so I didnt have to worry abotu marking them. If yours aren't, then be sure to mark the wires and be careful pulling them out as they can get stuck and you can pull the wire out of the boot.
Its magic!!
Yep, the O ring was leaking. **Note** As you can see in the pic, there are two little ears that stick into the camshaft. They are slightly offset so if you move the dizzy 180 degrees, it wont go back into the camshaft straight, itll be crooked.
Step 5: Take yoru knife/screwdriver/pick and pry the ring out of the lil slot its in. Since youre replacing the O ring, dont worry if it breaks: Its not a condom and your car wont get pregnant. If it does, thats weird. Sell the car immediately.
I purchased two O rings just to be sure, different sizes. The one of the LEFT is what I used as the one on the right was too fat. Fat O rings just won't cut it.
Step 6: Stick the dizzy back in, bolt it up and put the plugs wire back on. Just the reverse of what you did. Again, be careful putting the wires back in as you dont wanna cross em up. Your car will run slightly bad if you do
Step 7: Double check everything and crank her up! **Note** When I cranked my car, it ran rough. I shut it off immediately and double checked my stuff. I actually pulled the dizzy off and made sure I had it in correctly and double checked my wires. All was well.
So, I cranked her up again and after I let it run for a couple seconds, she smoothed out and all seems to be fine and well in the world, angels descending from heaven holding one long note and whatnot, it was pretty groovy. :D
I have yet to take her out on the road and test drive her. Also have to clean the bay so I can check and see if shes still leaking or not.
If there needs to be any changes or would like me to add anything, lemme know and I shall do so.
Enj0y!
Teh 3nd
mac_24_seven is offline   Reply With Quote
Old 10-14-2011, 04:04 PM   #2
92lxsleeper's Avatar
Default Re: DIY: Civic/del Sol/Integra distributor O ring replacement
this really does not need a how to. if it was the internal o ring/ seal, then yes.
92lxsleeper is offline   Reply With Quote
Old 10-14-2011, 04:08 PM   #3
The Grumpiest
grumblemarc's Avatar
Quote:
I was thinking the same thing but there are quite a few people that need pictures for every little job. This'll help them.
grumblemarc is offline   Reply With Quote
Old 10-14-2011, 04:19 PM   #4
People like you who take the time to take pictures is what diy is about, thank you for the effort.
By the way was that the original o ring?
FYI: the stock o ring from honda retails for about 2 bucks, I am not sure what you were pricing from majestic?
motegicivic is offline   Reply With Quote
Old 10-14-2011, 04:42 PM   #5
i take pictures and videos too, when i'm doing a complicated job. check out my youtube. its getting full of them.
Old 10-17-2011, 05:06 AM   #6
Man, I've done I dunno how many DIY's I've done over the years (check my Integra build thread) and the one that I have had the most questions over, even up until this day ( I have a message in my in box) is about replacing LED's in the gauge cluster.
Thats uber super simple, but I get stuff all the time over it and thats fine. Everybody is at diff levels of mechanical ability.
If nothing else, the part numbers are listed for anybody to quickly reference
Old 10-17-2011, 07:05 AM   #7
Keep it up, not many people take the effort to take pic and write it up, the pictures are helpful, people assume everyone on these boards are good mechanics, many are newbies.
Old 01-30-2012, 10:42 AM   #8
speedball3's Avatar
For what it's worth, I found this DIY very helpful. I've had a nagging oil leak for a while and assumed it was either the RMS or oil pan gasket. After searching a little on oil leaks, I learned A) Look top-to-bottom when searching for oil leaks, and B) the Dizzy o-ring is a common oil leak. A quick look definitely showed oil stains below the dizzy, easy diagnostic. After a trip to the local Honda dealer for the all-standard Honda dizzy o-ring (apparently 100% of Honda engines use the same o-ring), I was ready to go. I found that a previous mechanic had already marked the dizzy for me, which made that part easier (I was going to use white-out). Job was way easy... I was expecting a couple hours of pain and angst, but it turned out to be a quick 20 min job (felt that way at least). Dizzy pops straight off once the bolts are off and the old o-ring came off easily after I cut it/punctured it w/a flat-head screwdriver. It wasn't broken but extremely brittle, felt more like plastic than rubber. I had no problems using the standard Honda o-ring... fits easily and the dizzy popped right back in. Helms Manual said to put motor oil on the o-ring, which I did, so maybe that helped. Anyway, did a test drive, all was well, and car is running as smooth or smoother than before. Thanks for the confidence building DIY!
speedball3 is offline   Reply With Quote
Old 02-07-2012, 11:29 AM   #9
bpotter05's Avatar
thanks for the pics, helped this n00b out!
bpotter05 is offline   Reply With Quote
Old 02-08-2012, 12:12 PM   #10
:D
Old 02-19-2012, 11:05 PM   #11
Thanks, this helped me out as well. After looking at the photos I'm pretty sure I see the same oil leak happening in my car (stains on the tranny, also the crud on the distributor below the o-ring.) At first I was thinking it might be from the valve cover, but now I'm pretty sure it's the same distributor o-ring problem so I'll tackle that first.
goblazers is offline   Reply With Quote
Old 02-20-2012, 12:38 AM   #12
Texas4door's Avatar
Helpful and entertaining (the pregnant car bit gave me a chuckle)
Nice work!
Texas4door is offline   Reply With Quote
Old 03-31-2012, 11:34 AM   #13
caliskier's Avatar
Awesome, thanks for this. For me at least these DIYs really help. I am a shade tree mechanic, this part costs $2 and a mechanic would charge $100 plus the hassle of taking it over there etc. etc. It is just nice to see someone else do it so I don't make a simple mistake. And the boards don't get cluttered with duplicate threads.
caliskier is offline   Reply With Quote
Old 03-31-2012, 12:47 PM   #14
Arthas's Avatar
I recommend this cheap fix to EVERYONE! I just did it on my Accord.
Arthas is offline   Reply With Quote
Old 08-10-2012, 12:50 AM   #15
thank you for this guide it solved my problem. i have one question, when u replace the o ring did u have 2 washers behind those 2 "little ears" that go in the crankshaft because my one is very lose
nitroblast07 is offline   Reply With Quote
Old 08-10-2012, 07:12 AM   #16
Thread added to FAQs sticky.
Former User is offline   Reply With Quote
Old 08-10-2012, 07:41 AM   #17
fragmare's Avatar
Hah! A big writeup for a simple job, but I'm sure many a beginner will be helped by this. Funny too... I like the part about your car getting pregnant.
I'd also like to add that the Fel-Pro distributor o-rings seem to work well too. One came with my Fel-Pro head gasket set. They are orange in color instead of black. 6000 miles later and it hasn't leaked yet.
fragmare is offline   Reply With Quote
Old 09-08-2012, 08:59 AM   #18
I have a Problem. I went to the dealership, and they said that the o ring was broken. Well I went, and got the part just to find out that its the wrong o ring (I think). Can you guys tell me what to do with this little metal ring?
Michael H. is offline   Reply With Quote
Old 09-10-2012, 04:29 AM   #19
On majestic Honda's sight, they don't offer that as a replacement part. If I were you'd I'd go to a junkyard and snag one off a car there
Old 11-20-2012, 06:39 PM   #20
thanks alot bro this what i was looking for.
noob here
THANKS!
Skarface1988 is offline   Reply With Quote
Old 01-03-2013, 12:37 PM   #21
Just another person who at first assumed it was the head cover gasket and then came across this thread.
Many thanks for the illustrated walk through. Pictures are always helpful.
Everything worked exactly as planned.
stupiduser is offline   Reply With Quote
Old 01-03-2013, 07:24 PM   #22
This is why we have community forums :D
Old 01-28-2013, 02:54 PM   #23
clutchmaster2005's Avatar
I have the same problem but I have internal and external leakage on my Z6. I found the oil seals on ebay. Should I buy the ones on ebay or go oem from a honda dealership? The one on ebay interchanges with the dealership.
clutchmaster2005 is offline   Reply With Quote
Old 01-28-2013, 05:08 PM   #24
Quote:
I bought this one for the outside http://www.ebay.com/itm/140893937039...84.m1497.l2649
even with shipping I can't drive to the Honda dealer and get it for that price. And since I have 3 cars that use that seal I just bought a few which cut down on the shipping per piece.
belairbrian is offline   Reply With Quote
Old 04-06-2013, 03:01 PM   #25
wgwinatl's Avatar
Quote:
What you are pointing to is a metal snap ring (not an o-ring) and you would only remove it to get to the internals of the distributor. Check this video out on you tube, the guy shows it at 11:10
wgwinatl is offline   Reply With Quote
FAQ: ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic ** chameleon Honda Civic / Del Sol (1992 - 2000) 398 08-26-2017 12:17 PM
Write-Up: DIY Front Wheel Bearing Replacement OneBadTurboCRV Honda CRX / EF Civic (1988 - 1991) 77 09-23-2016 11:35 PM
D.I.Y EDM / JDM EK (96-98) Clock install thusee Honda Civic / Del Sol (1992 - 2000) 18 07-25-2016 08:36 AM
Detail engine bay with WD-40 (91 Civic Si) Rob. Detailing 36 03-13-2016 10:38 AM
DIY 96-00 Honda Civic Tune up and fuel filter HondaPartsHero Honda Civic / Del Sol (1992 - 2000) 56 03-09-2016 11:28 AM
Tags
civic, del, distributor, dizzy, honda, hope, integra, pugh, replace, replacement, ring, rings, seal, sol, write
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
