FAQ: ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic ** - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page > FAQ: ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic **
Old 08-29-2003, 07:18 AM
chameleon's Avatar
Default ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic **
I would like to start off by saying that this must be the most sought after mod to any 96-98 Hatch owner and has been something that i wanted to do since day 1. as i did more and more research i was discoured to find out that in order to have this done i would need to change the interior harness to 99+ as well as the ecu, engine harness while swapping the heater core and blower to 99+. way too much work involved to make this a worthful mod...
Until now more light was shed on this anticipated conversion, a recent thread started having to do with this conversion is what encouraged me to try this, when HT member "Pho Real" said "everything plugs up and bolts on" thats when i said ***** it, im gonna do it once and for all and finally show everyone the truth !!
Enuff blabber.. let get this show on the road!!
Notes: This "how to" is meant for anyone that will take a risk, i do not garantee anything or shall be responsible for any damage caused by attempting this conv. took me a total of 3 days to do this conversion since i took my time and was also taking pictures and had to wait a day to get the right blower, if you have removed ur dash before and have everything from the beginning it should not take long. just be prepared in case.
Tools Needed-
1) Socket Wrench
2) Sockets 14mm, 12mm, 10mm
3) Open Wrench 12mm
4) Socket Wrench Extension (at least 10in)
5) Extended Sockets 14mm, 12mm, 10mm
6) Philips Screwdriver
7) Pin/Hook Screwdriver
8) Pliers (to remove clamps)
9) A Friend.
10) Patience.
Conversion Requirements
1) 99+ Climate Control console with Climate harness (goes from console to heater core main plug)
2) 99+ Complete heater core Box
3) 99+ Complete Blower Box
4) 99+ Heater core harness (should be attached to the Heater core)
5) 99+ Center Dash vent (is contoured to position the vents to the right where the console has them)
6) Coolant.
Step1 - Removing the Unnecassary.
Disconnect the Battery (we dont want no surprises)
Start off by removing the Glove box. Open it and there are two rubber holders on each side, move them in and the box comes down. then just screws the 2 bolts on each side (4 total) and tape the screws the the GB and put it aside.
Next remove the armrest, so you can get to the shifter console so you can get to the cupholder area. i wont get into detail since this should be the least of worries. removing the cigarette console is 4 screws on each end. visible when the box box is out and the under steering wheel cover is removed.
Once the cig console is out remove the climate console. there is a cable that goes from the climate to the heater core bottom, trace is and remove it from the pin and holder. find the two screws in the front bottom of the climate metal shell and remove those. remove the hazard and defroster buttons carefully using a pin screw driver and there is a screw behind each button. remove the radio and unplug everything from the climate control. find any screws left and by now you should be able to carefully pop off the climate bezel.
The cluster is as simple as removing the 2 top cover screws and the 2 top and 2 sided cluster screws. unplug the cluster plugs and remove.
The Steering wheel rack can be removed from the top since its attached to the dash, there are two screws that hold it by the top and 2 that hold it near the middle. and can be seen after removing the top and bottom ignition covers. leave the rack attached to the steering knuckle (you can remove for more space but remember it will need aligning afterwards)
Step2 - Removing the Dash
there are total 10 screws that hold the dash in. if you study the above pic of everything removed you will see where i marked off their locations.
The 1st one is at the center top of the dash by the windshield, remove the cover and its there. 2 and 3 are visible once the glove box is removed they are between the main relay. (unplug that) 4 + 5 are in the middle where the cup holder normally is, they are a bit tough but can be gotten out, while there remove the extra 2 screws on the sides, will make things easier. 6 + 7 are under by the fuse box (unbolt that which are 2 mini 10mm screws on each side and keep it to the side, anything that maybe need to be unplugged will need to be pulled off) they are kinda hidden. 8 is in the door jam in the driver side u will see it when u pull that panel.
make sure that everything is unplugged from the dash!! double check everything u dont want to start pulling off the dash and something still be stuck. if all is good then yank that bish out !!
step3 - The Pain in da rear.
This is were it gets bloody, really. you have to pull the clamps off the 2 heater core hoses the run into the firewall, they are next to the cable for the temp control lever. and there is also a 12mm nut that has to be removed in order for the heater core box to come out. taking the clamps off must be the hardest part of this entire conversion because you are very space limited. depending the hybrid. not only that but once the clamps are off removing those set in hoses is another mission which i have the cuts and scrapes to prove it. NOTE: be warned that coolant fluid will leak everywhere when the hoses are removed, you can try and drain your coolant to help this step but i just let it drain out.
step4 - Removing the Main components
once you have the space to work with its much easier, disconnect the harness off the Heater core and the A/c box (if applicable) and the blower motor. there are a few metal screws and plastic screws that hold everything in, all 3 boxes connect with a lego effect but removing all the screws around all the boxes they will all come off very easily, if they dont come off easily double check for screws they are all over.
This is a shot of the MAIN Dash harness, this is what everyone thought would have to be changed to 99+
but in reality the 99+ heater core harness plugs right into it, no difference what so ever! see the proof..?
here you can see the differences between the 98 Heater core (left) and the 99 heater core (right) and as you can tell they are the same crap, except the 99+ has all the motorized stuff on the bottom for the temp control vs the pull and push cable ****. u can see also the 99+ harness attached to the core as it should be found.
the A/c core is the same in all the years and its the connecting piece it can be reused, nothing needs to be altered on it. Th Blower box is another story as i found out trying to rewire my 98 i blew about 7 fuses (same one) because the 98 is a power wire core and the 99+ is a power resistor core so they work the same but are controlled differently so i ended up getting the right one and things went a whole lot smoother. in the pic you will notice the plug differences, from a 4wire plug (98 - right) to a 3 wire plug (99 - left).
this is what everything will look like once everything is put back and harness is connected. ignore the blower plug since that pic shows my 98 blower in place before i exchanged it with the 99.
step5 - Changing the Dash center vent
this is something that has to be done in order for the 99 climate console to have the propper vent location, the two sides one are the exact same i matched them up but in order to change the middle one you have to remove the metal exoskeleton from the dash, basically remove every bolt that holds it on, carefull around the airbag area they are some there also. once that is removed there are maybe 4-5 bolts that hold the center vent in place.
replace that and put everything back in place.
this is what the acomplished goal should look like..
step6 - DOuble checking
This is where it gets exciting, you can connect the fuse box plugs, connect the ignition plugs and take the climate console and plug in its harness to the heater core. if everything else is disconneted (i.e. SRS plugs) then u shouldnt have a problem of anything going off but you might get an SRS light which i can show you how to reset which is very easy. but once you connect the battery stick your key in the ignition and turn to the on position. the fan should start working if its on in the climate. play will all the options and listen to the little motors in the heater core and blower start working. check every fan speed, every vent location and the temp control which is that little cable that comes out on the engine firewall. all the way to cold the cable will be extended, hot it will be retracted all the way in. or vise versa. when you hit the button on the bottom of the climate console next to the a/c and defroster the blower front plate should open and close, test that also. once you check that everything works properly you then are ready to start the opposite or removal process.
I gave my inspiration credit, if you decide to try this conversion at least mention my name chameleon anything i have left out i will add in when i remember or you can pm with questions.
EDIT: defroster fix added below..
"i just installed an entire 99 dash into my friends 97 ek hatch, when i say complete its complete with vents climate and 99 harness in it. now weather you use your own 96-98 dash harness or the 99 it dont matter BUT to get the rear defroster working you need to tap a wire (baby blue with a yellow stripe) from the big plug that sits in front of the heater core and tap that into the baby blue with yellow stripe wire on the big green plug thats in front of the fuse box, the wire is at the end of the plug next to a green wire. once u do that you will see your relay click."
Modified by chameleon at 3:08 PM 4/13/2008
chameleon is offline
Old 08-29-2003, 07:26 AM
B16b2b's Avatar
Default Re: ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic ** (chameleon)
still gotta say it sounds like more work to be worth having the newer **** setup, but great write-up. must have been a long prcess.
B16b2b is offline
Old 08-29-2003, 07:27 AM
96 SOHC VTEC's Avatar
Awesome right up! Looks like a time consuming project, but the end result is nice!
96 SOHC VTEC is offline
Old 08-29-2003, 07:30 AM
Brewer's Avatar
Default Re: ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic ** (B16b2b)
Wow, nice install
Brewer is offline
Old 08-29-2003, 07:34 AM
Spade's Avatar
Nice job, so not worth my time to do this swap though.
Spade is offline
Old 08-29-2003, 07:35 AM
chameleon's Avatar
yes it is, im not lying to everyone saying its not cause its time consuming and take a lot of effort + skill. i mainly wanted to shed the light on all the confusion that i even had before, and thats you do not need to change the dash harness to 99 or the engine harness or the ecu which still makes it not that bad...
Old 08-29-2003, 07:39 AM
chameleon's Avatar
Default Re: ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic ** (Spade)
btw no offense but im not looking for all the ones that know they will never do this... but yet the hardcore peeps that always wanted to know the answer... thats what makes all this work satisfying. not the negativity.
Old 08-29-2003, 07:50 AM
Dr. EKology's Avatar
Wow, very nice write up man! Took a lot of effort and skill! Feels good being the first and paving the way for others huh?
Dr. EKology is offline
Old 08-29-2003, 08:04 AM
Spade's Avatar
None taken. I for some reason or another feel the need to add my opinion to everything
Again, beautiful job, glad to see you took your time and did it right.
Spade is offline
Old 08-29-2003, 08:05 AM
B16b2b's Avatar
i agree with your outlook, b/c there has definetly been some misinformation given on the job, so good work man.
B16b2b is offline
Old 08-29-2003, 08:14 AM
leadtrum's Avatar
awesome tech article...seems like more a bitch than its worth but its something i've always wanted to do also.
leadtrum is offline
Old 08-29-2003, 08:19 AM
kikicamacho's Avatar
Thanks for showing us how it's done, and clearing up the wiring confusion. But I gotta agree with Spade, too much work for the end result for me. If I had the time to kill and nothing else to work on, I'd do this to my 97 hatch. But family+work= almost no time for car.
kikicamacho is offline
Old 08-29-2003, 08:34 AM
Petah's Avatar
Default Re: ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic ** (leadtrum)
Nice write up! Some good info i can use when i am installing my AC into my EK.
Petah is offline
Old 08-29-2003, 08:43 AM
HXMan's Avatar
Wow...nice job!
Maybe you could answer this question? Is there a replaceable air filter or something in the system. One day I had a horrible smell coming from my vents, that took about a month to go away. Now I get a wiff of it once in a while....I have no idea what it was.
HXMan is offline
Old 08-29-2003, 09:17 AM
Great work, and thanks for posting this!
BrotherGrim is offline
Old 08-29-2003, 09:29 AM
Filliam H. Muffman's Avatar
Default Re: (BrotherGrim)
yeah, thanks a lot, now you wanna help me with mine?
btw, cant you just buy a 99+ dash, and just use that?
how much do those go for anyways?
Filliam H. Muffman is offline
Old 08-29-2003, 10:16 AM
chameleon's Avatar
Default Re: ** Mother of all How-to's : 96-98 EK Manual Climate swap to 99-00 EK Electronic ** (HXMan)
Originally Posted by HXMan
Wow...nice job!
as far as i know and everything i overlooked there is nothing that can be replaced, heater core and blower arent a replacable item they are meant to be in the car for a while. not sure how a bad smell could start but i know it can happen. but then again i know old coolant slowly leaking inside the car is a damn awful smell by that point u just have to replace the leaky heatercore.
Old 08-29-2003, 10:18 AM
chameleon's Avatar
Default Re: (JUN EK9)
you can buy a 99 dash, and just replace the vin part in back, about 20 screws hold it in but then you would have to swap your harness into it, so either way you cant cut corners.
Old 08-29-2003, 10:42 AM
Default Re: (chameleon)
RED X's NOOOOOOOOOO
Black93DelSolSi is offline
Old 08-29-2003, 10:45 AM
Pho Real's Avatar
Default Re: (Black93DelSolSi)
Thank God you posted this, I did this mod about three days after I signed up for Honda-Tech and I had no reason to take pictures because I didn't know everyone on here would also like to do it. I have to say thanks To TonyXCom because he helped me out when I was trying to do it.
Pho Real is offline
Old 08-29-2003, 10:55 AM
elwood's Avatar
Default Re: (Pho Real)
I did this on my 92cx to the eg6 digital climate control.
Didnt take my time to do a write up because I still have
not finished it.
Great write up.
elwood is offline
Old 08-29-2003, 11:11 AM
atisvt99's Avatar
I can't see photos either...
atisvt99 is offline
Old 08-29-2003, 11:16 AM
Dan GSR's Avatar
Default Re: (atisvt99)
i think he should gain some H-T percentage for all these great how to's
Dan GSR is offline
Old 08-29-2003, 11:22 AM
tonyxcom's Avatar
WOW! We finally have the final word. Thanks.
I was going to do this before until I found out all the parts you needed so I said **** it. But I am glad that we finally have a thread to point someone too when a newb asks how to do this.
It's a lot of work, but so is color matching your engine compartment
tonyxcom is offline
Old 08-29-2003, 11:23 AM
Pho Real's Avatar
Default Re: (tonyXcom)
Oh yeah, Tony asked me to update him when I was finished but I forgot
Pho Real is offline
Emshhh
02-13-2018 03:23 PM
eskimo10
43
12-30-2017 10:25 AM
NOFX
08-19-2016 08:42 PM
Jstans84
Honda Civic (2001 - 2005)
12
03-20-2016 12:50 PM
HondaPartsHero
56
03-09-2016 10:28 AM
  • Ask a Question
Question Title:
Description:
