Installing JDM Mirrors (DIY)
Old 10-12-2003, 10:31 PM
Denny's Avatar
Default Installing JDM Mirrors (DIY)
I decided to put a little DIY for JDM folding mirrors w/ OEM relay. There have been some out there but they may be alittle confusing or unclear.
Materials Needed:
JDM Mirrors
OEM Relay Box
8mm Ratchet
Philips/Flat Screw Driver
Paper Clip
Wire Loom(not necessary)
22 or 18 guage wire
Electrical Tape
1.Take off Door panal
2. On the JDM clip that connects to the switch(green) you will see that there is an extra wire on the very left side. Remove this wire and put it in the exact spot in the USDM switch clip. You will need a paper clip to remove the wire.
3. You will then go the the clip that connects to the mirrors. Look at the JDM one and the USDM one. you will see that the JDM clip has 2 extra wires. Remove the 2 and put them in the same spot on the USDM clip. Use the same method with the paper clip to remove wires.
4. After you have done that, use the following diagram to wire mirrors and OEM relay box. You may put the relay box anyplace you choose. I decided to put the box in the driver side kick panel. Heres a diagram on how to wire them up.
5. This is how I put feed the wires from the door to the inside of the car. There are many ways to do it but I thought this is the most simplest way.
6. Your finished! Hook everything back up and make sure everything works!
http://www.we-todd-did-racing....DE%3D
Old 10-12-2003, 10:36 PM
B2FiNiTY's Avatar
Default Re: Installing JDM Mirrors (Denny)
Looks awesome! can't wait to see them in person.
Old 10-12-2003, 10:43 PM
b Team's Avatar
Default Re: Installing JDM Mirrors (B2FiNiTY)
bad ***
Old 10-13-2003, 12:25 PM
Denny's Avatar
Default Re: Installing JDM Mirrors (XSCDCXDC2)
thanks for the comments!
Old 10-13-2003, 12:33 PM
nightrider's Avatar
that's only the second vid i've seen of the power folding mirrors. badass.
Old 10-13-2003, 12:36 PM
hybridzOr's Avatar
Default Re: Installing JDM Mirrors (nightrider)
great write up
Old 10-13-2003, 01:18 PM
ChadB's Avatar
there a pain in the ***..
Old 10-13-2003, 01:29 PM
jbs
jbs's Avatar
I'm still trying to figure out how to be able to see from the driverside mirror (JDM passengerside). All I see is the side of my car. I'm sure you probably have this problem, what have you done to get around it? Thanks!
Old 10-13-2003, 01:30 PM
Denny's Avatar
Default Re: Installing JDM Mirrors (jbs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jbs &raquo;</TD></TR><TR><TD CLASS="quote">I'm still trying to figure out how to be able to see from the driverside mirror (JDM passengerside). All I see is the side of my car. I'm sure you probably have this problem, what have you done to get around it? Thanks!</TD></TR></TABLE>
i have this very same problem. you can either live with it or use the blind spot mirrors. i dont even use my mirrors anyways. i just look over my sholder, so its not really a big concern.
Old 10-13-2003, 01:36 PM
jbs
jbs's Avatar
Good for you. With my USDM mirrors w/blind spot mirrors, I never look over since I have a complete view. Guess, I'll have to get use to the fact I wont be able to do this anymore. Sucks!
Old 10-13-2003, 02:07 PM
NrG
NrG's Avatar
their should be a section in each forum for DIY
sometimes its hard to find old writeups..
great writeup
Old 10-13-2003, 02:30 PM
iLovPhoKing's Avatar
Default Re: Installing JDM Mirrors (NrG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG &raquo;</TD></TR><TR><TD CLASS="quote">their should be a section in each forum for DIY
great writeup </TD></TR></TABLE>
to that!!!
Old 10-13-2003, 02:38 PM
yakitori's Avatar
damn thats so tight I was gonna pick those up but this guy wanted $400 for um
Old 10-13-2003, 02:57 PM
Ricey McRicerton's Avatar
Why the hell would you get rid of windows that work for some JDM coolguy mirrors that you can't see out of??? Seems a little like you guys have jumped on the JDM bandwagon.
Old 10-13-2003, 03:16 PM
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Default Re: Installing JDM Mirrors (yakitori)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakitori &raquo;</TD></TR><TR><TD CLASS="quote">damn thats so tight I was gonna pick those up but this guy wanted $400 for um </TD></TR></TABLE>
If I like the look of integra mirrors on mine, I will sell you a set with the OEM relay, interior switch, covers, and mirrors for $240 shipped.
Old 10-13-2003, 03:18 PM
INVALID's Avatar
Default Re: Installing JDM Mirrors (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
Why the hell would you get rid of windows that work for some JDM coolguy mirrors that you can't see out of??? Seems a little like you guys have jumped on the JDM bandwagon.</TD></TR></TABLE>
Just remember "JDM coolguy" is your term and not mine, I honestly just like toying around with things (kid at heart).
For other resources:
http://students.washington.edu...3.gif
http://students.washington.edu...s.htm
https://honda-tech.com/zerothread?id=539424
http://www.courtlukens.com/folding_mirror.htm
Old 10-13-2003, 03:33 PM
JoshuaVTEC's Avatar
I've always liked the idea of wiring them up to your alarm, so when you arm it they fold in, when you disarm it they fold out
Old 10-13-2003, 03:34 PM
hybridzOr's Avatar
Default Re: Installing JDM Mirrors (JoshuaVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC &raquo;</TD></TR><TR><TD CLASS="quote">I've always liked the idea of wiring them up to your alarm, so when you arm it they fold in, when you disarm it they fold out </TD></TR></TABLE>
that would be pretty tight.....and scary...muhahahaha
Old 10-13-2003, 03:36 PM
hybridzOr's Avatar
Default Re: Installing JDM Mirrors (HybridRacer)
best use for a drill
Old 10-13-2003, 03:38 PM
Down Since Day 1
1 point 6's Avatar
Cool write up!
Old 02-16-2008, 07:16 PM
JoshuaVTEC's Avatar
Any chance someone still has these pics? Or a new link? I need to do this.
Old 02-23-2008, 06:58 PM
JoshuaVTEC's Avatar
Last try............
Old 05-26-2008, 10:15 PM
New User
a.6262's Avatar
how do i get to see the pics? my comp has the pics X out
Old 05-26-2008, 10:59 PM
mogge's Avatar
Default Re: Installing JDM Mirrors (a.6262)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a.6262 &raquo;</TD></TR><TR><TD CLASS="quote">how do i get to see the pics? my comp has the pics X out</TD></TR></TABLE>
old thread.. pictures just need to be re-hosted.
Old 05-27-2008, 03:24 AM
JoshuaVTEC's Avatar
Default Re: Installing JDM Mirrors (mogge)
Someone make this happen............
Quick Reply: Installing JDM Mirrors (DIY)
