B16 Bottom End Assembly - Complete Walk through - Maybe Sticky
With the engine back from getting machined and cleaned, set the motor on a clean area.
Many motor shops will tell you which piston to use in which cylinder even though all cylinders and pistons should be the same size.
Make sure the wrist-pin is lubed and the gaps are placed correctly. Never put a cap inline with the pin or in a thrust area.
Get a rag and oil the cylinders heavily prior installing the pistons.
There should be plenty of oil on the cylinder walls.
Take your ring compressor (I love my ARP one), oil the inside heavily and compress the rings on the piston.
Push the piston into the cylinder gently, if a ring gets caught on the cylinder wiggle it around a little while pushing. Do not force it, it does not take much to break a ring.
There she goes.
That is one done.
Repeat the process for the other 3, making sure that each cylinder and piston is well oiled, along with the ring compressor.
That is two done
Pushing in the 3rd one
That is three done.
Pushing in the last one.
That is four done.
Well theres a half way built bottom end
Laying out the rod bearings. There is not a difference between the upper or lower ones.
Here is a rod cap.
Notice the notch in the corner.
Notice the notch in the corner of the rod bearing.
Match the notches up and push the bearing into the rod cap.
Here is the bottom of the rod. Once again, notice the notch.
Lube up the rod bearings on the rods.
Lube up the rod bearings on the rod caps.
Here is the main bearing. On ACL bearings that have a U or an L to distinguish the upper and lower bearings. This is an upper bearing, meaning that it goes into the block.
This is the lower bearing, meaning it goes on the main cap.
Here is a main cap. Once again there is that notch.
Line up the notches and push the bearing into the main cap.
Lube the bearing in the main cap.
On to the block. yep, there is that notch.
Match the notches up and push the bearing into the block.
Lube it up.
I also like putting more assembly lube on the wrist pin.
The thrust washers are inserted. If you put assembly lube on the back of them, they will stay in place while you get the crank in.
With everything lubed, its time to drop the crank in.
Looks good lets start bolting up things
Rotate the crank until the 2 middle rods or 2 end rods line up.
In my case the middle rods lined up first.
Lube the ARP bolt with ARP lube.
Looks good... now smear it on the threads
Place the rod cap on
Well place both rod caps on
The correct order is labeled above
Torque them down according to specs. I always torque them first to half the final torque specs. then increase in increments of 10 until the specified torque is reached.
Still tightening.
Rotate the crank until the end rods line up.
Forgot to mention on the middle two, I like putting assembly lube on the crank too.
Tighten those rod caps up too.
Well the rods are done, moving onto the mains.
Lube the ARP main bolts with ARP lube.
Lube the ARP main bolt washers with ARP lube. This will lessen the friction between the block and head of the bolt.
Lube the ARP main bolt nuts with ARP lube. Just put a little lube on the bottom side of the nut, to lessen friction.
Looks lubed to me.
Start tightening the main bolts. I always torque them first to half the final torque specs. then increase in increments of 10 until the specified torque is reached. For example torque specs were 70. I started at 30 tightening all of them then 40 then 50 then 60 then 70. Then doubling checking them.
Well the crank and rods are bolted in.
Rear main.
Rear main seal.
This stuff is pricey but well worth it.
Rear main seal all Hondabond-ed up and ready.
Well the rear main is ready to roll.
Scatter shield.
It goes here.
I like to Hondabond these bolts, since lock tight would be a bad idea.
Well the scattershield is on.
The oil pump all cleaned with brakekleen and ready to go.
Hondabond-ed and ready to roll.
Yea that's where the oil pump is going... make sure the meeting surface is oil free.
Now its time for the oil pick up.
Put the oil pick-up on.
I like to put some Hondabond on the block and oil pan.
Just like that. It will push the gasket out some when tightening since it'll be slippy, so don't over tighten the bolts.
Line up the oil pan gasket on the block.
Like this.
Then finish up by bolting the oil pan on. The bottom end is now done.
Re: B16 Bottom End Assembly - Complete Walk through - MaybeSticky (doublejz)
Note this is after everything has been plastiguaged and checked for clearances.
Re: B16 Bottom End Assembly - Complete Walk through - MaybeSticky (hardEH2)
nice write up! I think if you posted up the plastic gauging and how you came up with what bearings would help just a little bit more. But still a great write up non the less!!
Re: B16 Bottom End Assembly - Complete Walk through - MaybeSticky (RICE POLICE SIP)
Awesome Writeup dude! PM a mod, this should def go in the FAQ's! Awesome work!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz »</TD></TR><TR><TD CLASS="quote">Note this is after everything has been plastiguaged and checked for clearances.</TD></TR></TABLE>
Seriously along with the ring gap and such. Those are the most important in building a motor. Also the machine shop wanted you to use which piston in which cylinder because they used that piston for that cylinder when they bored it.
Other then missing a few things this is a good write up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICE POLICE SIP »</TD></TR><TR><TD CLASS="quote">nice write up! I think if you posted up the plastic gauging and how you came up with what bearings would help just a little bit more. But still a great write up non the less!! </TD></TR></TABLE>
x2
x2
* B A N N E D *
Re: B16 Bottom End Assembly - Complete Walk through - MaybeSticky (slowinteg)
check for cleances with a feeler guage, also torque specs could be found under a del sol vtec trim or 99-00 civic em1
scatter tray= windage tray
Re: B16 Bottom End Assembly - Complete Walk through - MaybeSticky (spork motorsports)
plastiguage > feeler guage
Specs vary depending on parts.
As shown in the pictures, I used ARP bolts. The del sol vtec trim torq is different then the ARP. Use the specs for the parts that you purchase.
Also, to be a real PIA you can do bolt stretches using a Rod-Bolt Stretch Gauge to be 100% perfect http://www.chevyhiperformance....info/
move to FAQ...
Modified by doublejz at 8:51 PM 3/16/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz »</TD></TR><TR><TD CLASS="quote">sticky me</TD></TR></TABLE>
No offense but i dont think there going to sticky this. If you PM Bense hell update the first page list of FAQs but it wont be sticky. Theres alot of good write ups out there that other people have done that if we stickied them all we wouldnt have a first page. Nothing personal.
Re: B16 Bottom End Assembly - Complete Walk through - MaybeSticky (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
No offense but i dont think there going to sticky this. If you PM Bense hell update the first page list of FAQs but it wont be sticky. Theres alot of good write ups out there that other people have done that if we stickied them all we wouldnt have a first page. Nothing personal. </TD></TR></TABLE>
Yea true that,he wont sticky it,but im sure hell put it on the FAQs
Re: (ek4h)
nice write up man....if anyone wants another one with more details....check this GSR BLOCK ASSEMBLE
http://www.evans-tuning.com/tech1.html
Re: (B18CivicEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEH2 »</TD></TR><TR><TD CLASS="quote">nice write up man....if anyone wants another one with more details....check this GSR BLOCK ASSEMBLE
http://www.evans-tuning.com/tech1.html</TD></TR></TABLE>
Wow, that was really nice! Awesome write up by those guys. The guys at Evans-tuning are amazing.
Re: (doublejz)
One major problem here.
Torquing down in 5 ft-lbs increments is a very bad and unsafe practice. The break-away torque on the bolt/nut is in most cases more than 5 ft-lbs.
Also, never put hondabond over the entire oil pan gasket. You are gonna get leaks for sure. The steel pan will flex hondabond doesn't make for a good fit when it does flex. It should only be put in the corners of the oil pump and rear cover.
Other than that, good job.
