Oil lines mounted on firewall...basic walkthrough
Old Jan 5, 2003 | 08:05 PM
B18EG6's Avatar
Default Oil lines mounted on firewall...basic walkthrough
Hello-
I have been getting a few IMs regarding my original thread on the oil lines mounted on the firewall thread:
https://honda-tech.com/zerothread?id=377208
I thought I would update the forum with a part number from McMaster for a 1/8" BSPT male to a -4AN male union fitting. The part number is 4545K151
I hope this helps
Seb
Edit - forgot to mention... the lines I speak of in that thread (4468k401) have an ID of 3/16 (-3AN equivalent) but the fittings accept 7/16-20 threads (-4AN equivalent)
<FONT COLOR="blue"><FONT SIZE="4">Scroll down please</FONT></FONT>
note to self....
1/8" NPT male - 1/8" BSPT female
4092k26
1/8" BSPT male - 1/8" NPT female
4092k11
<FONT COLOR="red">Addendum: there is an error on my part, props to FwdCivicHatch for pickin it up... the BSPT male to NPT female has the correct part number above (4092k11) and incorrect part number throughout the writeup</FONT>
Modified by B18EG6 at 11:37 PM 4/5/2004
Modified by B18EG6 at 9:31 AM 4/10/2007
Old Jan 5, 2003 | 08:09 PM
SiRkid's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (B18EG6)
good info!
Old Jan 5, 2003 | 08:11 PM
easy jesus_151's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (SiRkid)
nice.
Old Jan 5, 2003 | 08:21 PM
B18EG6's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (erknjerk151)
Thanks!
here is another picture of the tee on the firewall. Note a plug in the rightmost position. This is for the addition of an aftermarket oil pessure sender in the future.
NOTE: its the tee with the green loop holding it up. The other tee is the result of yesterday's boredom. The wac lines use brass tees instead of plastic ones
[Modified by B18EG6, 12:21 AM 1/6/2003]
Old Jan 5, 2003 | 08:27 PM
BlueShadow's Avatar
SWEET!!!!!!
Old Jan 5, 2003 | 08:33 PM
shortyz's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (BlueShadow)
where u get those SS lines?
Old Jan 5, 2003 | 08:42 PM
B18EG6's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (shortyz)
I got them from mcmaster.com
search for teflon hose..i got the stainless steel ends. Get the male union to male union, with 1/16th inner diameter.
part number 4552k421
Old Jan 5, 2003 | 08:50 PM
FULLTHROTTLE's Avatar
Nice work man. Oil lines are probably the most overlooked on a turbo setup but htey can cost you if they are done wrong.
Old Jan 5, 2003 | 09:04 PM
Speed PHreak's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (FULLTHROTTLE)
Good stuff
Old Jan 5, 2003 | 10:01 PM
youngkow's Avatar
Very nice. Thanks!
Old Sep 20, 2003 | 12:44 PM
E46M3CB's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (youngkow)
can someone please provide pics to this thread? ive done an archive search also but this seems to be teh most helpful...
Old Sep 21, 2003 | 01:58 AM
E46M3CB's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (serenity)
up...
Old Sep 21, 2003 | 06:48 AM
metal-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by serenity &raquo;</TD></TR><TR><TD CLASS="quote">can someone please provide pics to this thread? ive done an archive search also but this seems to be teh most helpful...
Old Sep 21, 2003 | 06:34 PM
B18EG6's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (metal-x)
do the pictures work now? may have gotten erased from my school server, i forget which those are linked to...
if they dont work please IM me and i will make a new thread, or update/add to this one
Old Sep 21, 2003 | 06:38 PM
B18Flip's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (Speed PHreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed PHreak &raquo;</TD></TR><TR><TD CLASS="quote"> Good stuff</TD></TR></TABLE>
Old Sep 21, 2003 | 07:18 PM
mos's Avatar
mos
Default Re: Oil lines mounted on firewall...basic walkthrough (B18Flip)
Nice bracelet.
For you poor guys, their brass teflon hoses are cheaper and work just as well, and you can save another few bux by going with the npt male on one end and JIC swivel on the other. Like I did. Crimping your own lines is a pain in the butt. Its easier to just buy some like these!
Old Sep 23, 2003 | 09:37 AM
mos's Avatar
mos
Bump for an informative post!
No reason to over spend on this stuff. Unless you need more bling.
Old Sep 23, 2003 | 03:07 PM
metal-x's Avatar
Default Re: (mos)
nice thanks for the info
Old Sep 23, 2003 | 03:21 PM
intekragsr's Avatar
Default Re: (metal-x)
what was your total cost?
Old Sep 23, 2003 | 03:38 PM
FuzzyGreen's Avatar
why do you have an injector on your firewall?
Old Sep 23, 2003 | 03:59 PM
93TurboSi's Avatar
whats is bspt and why do you need it? my greddy kit used all 1/8npt and they went in to the block and the oil sensor plugged in fine. So why would you need the special bspt if the 1/8 npt fits fine?
Also whats the difference between getting hose with male couplings and hose with male union couplings?
Just wondering before i order parts.
Modified by 93TurboSi at 2:11 AM 9/24/2003
Old Sep 23, 2003 | 04:09 PM
ScrapinSi's Avatar
Where the hell was this post 2 weeks ago??? ARRGGGHHH!!!!
Good post... I can still use parts of it...
Old Sep 23, 2003 | 04:39 PM
B18EG6's Avatar
Default Re: (intekragsr)
I cant seem to find the screenshot of the final cost... but with the brass fittings instead of SS i remember it being around 45 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">why do you have an injector on your firewall?</TD></TR></TABLE>
What do you mean? What are you referring to? I think you might be mistaking the oil pressure sender with the injector
Old Sep 23, 2003 | 04:53 PM
brcivic411's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (ScrapinSi)
good stuff.. i've been meaning to redo this and i think i will now
Old Sep 23, 2003 | 06:22 PM
B18EG6's Avatar
Default Re: Oil lines mounted on firewall...basic walkthrough (brcivic411)
ok guys i got a killer walkthorugh with part numbers and pics of each.. just hafta upload all that stuff now... either on WTDR or on my school server tomorrow
