DIY: 94-01 Integra Cluster into 92-95 Civic - Honda-Tech - Honda Forum Discussion
Old 10-29-2008, 10:06 PM
danomatic93's Avatar
Default DIY: 94-01 Integra Cluster into 92-95 Civic
This is a detailed DIY for installing a 94-01 Integra Cluster into a 92-95 Civic. You are more that welcome to use this as a guideline as there are many ways of displaying the cluster.
Tools/Items Used:
Knife (Small Flat Head Driver)
Masking Tape
Heat Gun
Dremel (Cutting and Sanding Bits)
Ove Glove
Safety Glasses
94-01 Integra Cluster with Pigtails (I used a 94-97 Cluster)
92-95 Civic Cluster Bezel
Acrylic (Plexiglas)
Epoxy
Flat Black Spray Paint
Sandpaper
Small piece of a paperclip
EG trip odometer stick rubber end
1” nylon sleeve with O.D. ¼” and 6-32 thread size inside
2” 6-32 threaded rod
Civic Cluster Bezel Preparation:
Let’s start by getting the Civic Cluster Bezel ready. I wanted the have a clean stock feel with these gauges, so I wanted to use a stock bezel (well, really just the frame of it.).
1. Remove the Bezel from the donor Cluster. 5 tabs, use ‘em.
http://i106.photobucket.com/al...8.jpg
2. With a knife, shove it in between the Bezel and the plastic cover. Work your way around the cover, carefully prying up the cover as you go.
http://i106.photobucket.com/al...7.jpg
3. Mask off the inside of the Bezel with tape to protect it from scratches later.
http://i106.photobucket.com/al...9.jpg
4. Get out the Dremel and cutting disc and cut it out. Leave extra material to sand down so that you don’t scar the Bezel.
http://i106.photobucket.com/al...0.jpg
WEAR SAFTEY GLASSES!!
You can see how much I left to sand here:
5. Again with the Dremel, but now with the sanding tubes. Sand it flush.
Note: I also hand sanded with 180, 360 and 600 grit sand paper after using the dremel.
6. Trim three tabs of the Bezel.
Before:
http://i106.photobucket.com/al...3.jpg
After:
7. Lightly scuff the surface with fine grit sandpaper (600+), clean with alcohol and let it dry, then paint flat black.
Integra Cluster Preparation:
Get out the Integra Cluster
1. Remove the Bezel on the Integra. Tabs and 3 screws in the back!
2. With the Bezel off, remove the clear cover and cut the Bezel with a Dremel.
Note: the Bezel is on the cluster just for the picture; do not cut with the Bezel on the cluster. You will screw up!
Note: I cut down some fins on each side.
Note: I trimmed this lower part of the Bezel to allow the Civic Bezel to sit on this Bezel more easily.
To fit the cluster into the car I had to cut down the cluster’s sides a little. Both sides were cut the same.
3. Test fit, Test fit, Test fit!!!
http://i106.photobucket.com/al...2.jpg
Stop and admire a side by side.
http://i106.photobucket.com/al...1.jpg
4. Add extra material on the upper corners of the bezel where there is a gap between the integra bezel and civic bezel.
Note: I used extra Plexiglas and epoxy then sanded it flat.
5. Lightly scuff the surface with fine grit sandpaper (600+), clean with alcohol and let it dry, then paint flat black.
It should look something like this:
6. Extending the trip odometer stick:
Random parts I used-
-a small piece of a paperclip
-EG trip odometer stick rubber end
-1” nylon sleeve with O.D. ¼” and 6-32 thread size inside
-2” 6-32 threaded rod
To do it:
a. Drill a small hole in the Integra trip stick to receive half of the length of the paperclip piece you cut. This is used allow the extension something to hold onto.
b. Epoxy the paperclip piece in place.
c. Push the EG trip end onto the threaded rod.
d. Cut down the threaded rod a little. Be sure the nylon sleeve can still thread on.
e. Now, you can epoxy the extension on OR build up the diameter of the paperclip with epoxy so that the extension slides on snugly without being permanently attached.
Custom Cluster Cover Preparation:
We want our final product to have a hole for the trip odometer reset stick to be in the right spot. Yes, you can use the stock cover BUT, you’ll have a hole in the wrong spot. So, let’s make our own cover!
Get some acrylic (Plexiglas) from your local hardware store.
1. Cut the Plexiglas to rough length. Notice that it’s flat, for now.
2. Pull out the Ove Glove and Heat Gun and begin to evenly heat the Plexiglas.
3. While heating the Plexiglas apply pressure by bending it slowly. Do this until it has the same curvature as the stock cover.
4. Cut the Plexiglas to rough shape.
5. Cut the whole for your extended trip odometer stick.
6. Remove the protective plastic on both side of the Plexiglas. TIP: if it doesn’t come off easily, soak the cover in water for 5-10 minutes.
7. Epoxy the Plexiglas cover on and trim it down if you need.
Getting the bezels together:
1. Epoxy them where you see fit.
Wiring:
Wiring charts found on Honda-Tech:
https://honda-tech.com/zerothread?id=1053318
The Final Product:
Modified by danomatic93 at 7:56 AM 10/30/2008
danomatic93 is offline
Old 10-29-2008, 10:23 PM
civicjoe's Avatar
Default Re: DIY: 94-01 Integra Cluster into 92-95 Civic (danomatic93)
Any Pics of it complete in the car? Lookin pretty good I might have to take my gsr cluster back out and do this.
civicjoe is offline
Old 10-30-2008, 12:52 AM
blinx9900's Avatar
would love to see this installed
blinx9900 is offline
Old 10-30-2008, 02:34 AM
BlueIntegraBoy's Avatar
Default Re: DIY: 94-01 Integra Cluster into 92-95 Civic (blinx9900)
Subscribed to see the results
BlueIntegraBoy is offline
Old 10-30-2008, 03:53 AM
hpmx18's Avatar
good **** ima try it out this weekend
hpmx18 is offline
Old 10-30-2008, 07:01 AM
I added some final product pictures. Add your final pics when you do it! And add any suggestions that you may have.
Old 12-02-2008, 03:37 PM
The Final Product:
Night Driving Time Lapse:
http://s106.photobucket.com/albums/m...t=MVI_0794.flv
Old 12-02-2008, 03:39 PM
Old 12-02-2008, 03:42 PM
Resident Gearhead
BryanM.'s Avatar
That looks great
BryanM. is offline
Old 12-02-2008, 03:54 PM
patotas's Avatar
good job. looks great !!!
patotas is offline
Old 12-02-2008, 04:47 PM
BiggieBert's Avatar
Looks much better than my swap! lol good job, I wouldn't want to do this with a itr cluster though!
BiggieBert is offline
Old 12-03-2008, 07:02 AM
Yeah, I did it to an LS so I had no worries at all. Also, the LS has the closest to my stock redline in my EG.
Old 12-03-2008, 07:24 AM
mikehawk's Avatar
seems like a lot of work lol but integ clusters are pretty i might do it if i happen to find one layin around since I can't seem to get my wiring for my gauge lights straightend out .. lol
mikehawk is offline
Old 12-03-2008, 08:27 AM
Mr. Koy Noi
Lasty K's Avatar
Very nice DIY, kudos to you.
Lasty K is offline
Old 12-03-2008, 09:04 AM
Wow. Awesome man. =D
Mrmatt3465 is offline
Old 12-03-2008, 09:12 AM
Mingo's Avatar
nicely done sir
Mingo is offline
Old 12-03-2008, 12:53 PM
J*spec-EG6's Avatar
Nice work man!
J*spec-EG6 is offline
Old 12-03-2008, 02:52 PM
rickkane's Avatar
That's so sick. I'm doing that! Anyone want to buy a jdm SiR cluster?? GSR is the isht. Best one so far, pimp. Good install, no hacking
rickkane is offline
Old 12-30-2008, 06:50 AM
93preludeh22's Avatar
http://i106.photobucket.com/albums/m...e/IMG_0721.jpg
In the above picture, How much of that lip do you need to leave on the bezel?
93preludeh22 is offline
Old 12-30-2008, 07:11 AM
joshsayswhatt's Avatar
a little too strenuous for me ha, but good outcome, if i had spare time i'd attempt it, but real quick question? how do you match the speedo and everything from integra to civic, is it exact of just close?
joshsayswhatt is offline
Old 12-30-2008, 08:31 AM
I left very little, about a quarter of an inch or less. But, it's up to you.
Old 12-30-2008, 02:59 PM
maybe it will make sense when I try this... what do you mean it is up to me?
EDIT: I am at this step now... do I trim the bottom at all? Or just the top? should I use the same height as the bottom all the way around?
Thanks!!
Old 01-06-2009, 04:38 PM
Here's my final product:
One of the cluster lights was out... picked up some amber lights
Because I am tall, this is how I see everything when driving
I ended up cutting the little white spacer off the civic bezel and placing it between the new cluster. I also used blue masking tape for the little holes in the top left/right corners and just sprayed them black with the rest of the cluster.
Old 01-08-2009, 11:46 PM
Awesome job 93preludeh22!! Looks great! Sorry about not getting back, but it certainly looks like you got it done.
For everyone else, to elaborate on my previous response, the reason I say "it's up to you" I mean just that. There are sooooo many ways that you can get the pieces to match up and fit. I just chose one. I just cut until it looked good together with test fitting.
Old 07-31-2009, 11:35 PM
sp00ledbseries's Avatar
Damn dood that turned out sick good write up. Link saved for future reference
sp00ledbseries is offline
danomatic93
55
02-06-2018 08:35 AM
danomatic93
49
07-13-2015 07:42 PM
danomatic93
11-20-2009 07:55 AM
danomatic93
02-23-2009 05:56 PM
danomatic93
05-22-2008 10:07 PM
  • Ask a Question
Question Title:
Description:
