Hondata s300 help
Old May 11, 2014 | 06:05 PM
GABOCRX's Avatar
Default Hondata s300 help
I need some help with the Hondata s300 overheating protection parameter. When I run with the protection at 210-220 degree the engine don't rev over 4,000rpm, but change the parameter to 40 degree (check engine ON) the engine rev normal to the limiter 9,200rpm. This test was with the car on neutral. Thanks
Old May 12, 2014 | 08:27 AM
mtber's Avatar
Default Re: Hondata s300 help
By default the over heat protection throws a code and has a default revlimit of 12500 in the stock calibrations.
You need to set the over heat protection rev limit to an appropriate rpm.
It also sounds like you may have a launch control configured & don't know about it.
Look under the launch control tab to see if this is the case.
hondata s300 has really cool protection features.
Old May 12, 2014 | 08:35 AM
ef2_civic's Avatar
Funny because I have mine set at 210 overheat protection and I can change my rev limiter without a problem
Old May 12, 2014 | 09:17 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Me too...
Old May 12, 2014 | 02:58 PM
GABOCRX's Avatar
Thanks. I will try the reduce the rpm on the parameter. The funny thing is that a 40 the engine rev nice, change to 210+ don't pass 4,000rpm. Launch control is disable. Maybe the coolant sensor has some problem.
Old May 12, 2014 | 05:12 PM
DO IT ON ALL FOURS
What does your datalogs read? That would tell you right away what is going on... that is the whole point of an EMS to begin with after all - to be able to see and modify as needed.
Old Jun 15, 2014 | 11:07 AM
GABOCRX's Avatar
Any help!!!!
Old Jun 15, 2014 | 11:16 AM
GABOCRX's Avatar
The inyectors are the RDX with the correct dead time. In the overheat protection at normal 212F don't past 4,000rpm at 80 degree or less rev normal. The problem start with the v1 s300, I change to v3 last week the car work great, today same problem again.
Old Jul 20, 2014 | 08:33 PM
2000CTRSi's Avatar
Just set the overheat protection rev limit...
Old Jun 7, 2015 | 09:41 PM
ThE HeLLRaZoR's Avatar
Old thread. But that Speed Sensor was way fishy considering both Launch Control and Vtec use that Sensor..
If you have a Speed Sensor issue than your going to have to modify the Calibration beyond normal...
Si Jeff
Jan 19, 2006 10:23 AM
digital sol
Jan 2, 2005 08:49 PM
done
Jun 8, 2004 09:00 PM
