s300 help
Old Sep 21, 2014 | 12:07 PM
CRX91SE's Avatar
Default s300 help
Ok i had this working the other day, i un installed the program while i was clearing out allot from my laptop. Now i cannot connect the s300 to my pc. I am using windows 7.
Things i tried
-Cheking in device manager / no usb drivers are there
-Update drivers / wont work error code comes up
-Tried older version of smanager
-I can hear the usb connect to computer
-Stays in offline mode
-Green light is on
Any help or suggestions ? should i update my windows ?...
Old Sep 21, 2014 | 12:19 PM
CRX91SE's Avatar
Default Re: s300 help
i know my usb drivers are working i can install others but it wont install the s300 ones.
Old Sep 21, 2014 | 07:15 PM
CRX91SE's Avatar
this is the best i can get it says drivers installed. wont do anything
this is device drivers
Old Sep 23, 2014 | 07:50 PM
ThE HeLLRaZoR's Avatar
Sounds like something I used to do... Gotta know exactly what your deleting don't just guess. Something with your Communication Drivers or something. Usually the easiest thing to do in this situation if you don't have a computer savvy friend? Is just backup anything you want/can keep on to an external jump drive and do a factory restore. Make sure you save copy's of your Calibrations to the jump drive to. Infact you should already be doing that anyways...Good luck *** her right in the *****!
Last edited by ThE HeLLRaZoR; Sep 23, 2014 at 08:14 PM. Reason: Fuk her right in the Pussy!
Old Apr 20, 2015 | 02:38 PM
Rugger53's Avatar
I'm having all of the same problems that you are and can't get this figured out. I have the V2 and cannot get the driver to install on my Lenovo G560 with Windows 7. I paid to have this set up on a dyno so I'm not wanting to change anything, but I do need to be able to read the error codes. Could we please start this conversation again?
Old Apr 20, 2015 | 09:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You have to load a calibration into SManager in order to get the connect icon and upload icon to be enabled. Your screen shot shows no calibration in memory.
Rugger53
Engine Management and Tuning
Apr 29, 2015 05:10 PM
CRX91SE
12
Sep 22, 2014 10:17 AM
SOHCD16y8
Aug 8, 2005 02:17 PM
XXXRacing
Mar 10, 2003 07:23 PM
maderfacker
Jun 6, 2002 09:11 PM
