Tuning: Compression Ratio Change Questions
Old Jun 1, 2014 | 08:15 PM
the_yblegal's Avatar
Default Tuning: Compression Ratio Change Questions
In the process of assembling 11:1 pistons in a B16, stock stroke.
Is there a relationship between compression ratio and ignition timing? As compression goes up, does timing need to go down? Go up? Or no change?
Just wanting to be in ball-park for street tuning. Dyno time is expensive around here, so the closer I can get it on the street, the better.
I'm a beginning tuner, self-teaching, have already tuned afr for 10.4:1 on the street, ran 8psi. Looking to continue to run 8psi, just have more off-boost power for my daily driver. All input is appreciated!
Old Jun 1, 2014 | 08:20 PM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Tuning: Compression Ratio Change Questions
Higher compression speeds up combustion so less advance is needed to put the BMEP on the piston top at the correct angle of attack (14-18 ATDC).
Old Jun 2, 2014 | 04:39 AM
Flr Power's Avatar
Also no need to run below 11:1 afr.
Old Jun 2, 2014 | 11:15 AM
I agree. What I wrote wasn't clear; Motor was afr tuned at 10.4:1 compression on the street. I mean, I didn't tune timing, used boost retard 1deg per lb of boost. Afrs were around 11.5 wot. Stock JDM B16.
Old Jun 2, 2014 | 11:31 AM
Is the correct angle of attack calculated from anything? Thanks for the answer, learned about BMEP.
Old Jun 2, 2014 | 04:50 PM
Flr Power's Avatar
It happens to be like that and varies slightly from engine to engine internal configurations.
MikhailBjornson
Mar 28, 2017 06:09 PM
4genaccordfreak
Apr 30, 2014 06:28 PM
1.8T_EG
Apr 29, 2003 04:46 PM
RICHJ
Feb 18, 2003 05:48 PM
