Neptune y8 map timing sync question
No.
Your base timing (distributor) should be set, per the FSM, to whatever the base timing is under the Main tab in the NepTune preferences. Same tab where you calibrate the TPS.
GReddyB18C
Sep 7, 2002 05:24 PM
