need help!! with install of s300
Old Jun 4, 2014 | 11:17 AM
magicm's Avatar
Default need help!! with install of s300
I have a new laptop with windows 8 and I cannot get s300 software. I go to the sight an go through the motions and then at the end it reads error
Old Jun 4, 2014 | 11:28 AM
Muckman's Avatar
Moderator in Chief
Default Re: need help!! with install of s300
...and the error is?
Old Jun 4, 2014 | 11:41 AM
magicm's Avatar
exactly. it just reads error.
I don't know if anyone has tried or was successful with the installing on windows 8
Old Jun 4, 2014 | 11:56 AM
Muckman's Avatar
Moderator in Chief
Hondata says Smanager supports Windows 8.
Try the Hondata forum. http://www.hondata.com/forum/
Old Jun 4, 2014 | 04:24 PM
magicm's Avatar
This is what im getting
Old Jun 4, 2014 | 06:29 PM
Muckman's Avatar
Moderator in Chief
Do you have Smanager running in the background? Make sure smanager.exe is not running. And if it still doesnt work, uninstall any older versions of Smanager first.
Old Jun 4, 2014 | 08:08 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Had same issue before. Uninstall older version first then install new version. Unless this is a clean install then be sure to install as administrator.
Old Jun 5, 2014 | 07:01 AM
magicm's Avatar
I don't know what it means to install as administrator
however I deleted all old versions, then rebooted and installed again. this time it installed all the way then said error. I will try to screen shot
Old Jul 8, 2014 | 10:42 AM
zerovandez's Avatar
I have it installed on my Windows 8.1 x64 laptop without issues.
Download the file to your desktop. After it's done, right click the file, and select "Run as Administrator." Click yes or okay or allow in the "user access control" prompt if it comes up. Install and enjoy.
zerovandez's Avatar
Edward
Feb 10, 2005 06:12 PM
oemDC2
Dec 21, 2003 01:52 AM
