neptuneRTP: using B5 AC switch for map switching
Old Nov 9, 2014 | 06:19 AM
gabrielsousa's Avatar
Default neptuneRTP: using B5 AC switch for map switching
i would like to use B5 for map switching.
i press the AC switch several times, but on log DONT shows that AC is on,
what i'm doing wrong ? do i need to wire something ?
Old Nov 9, 2014 | 01:12 PM
Default Re: neptuneRTP: using B5 AC switch for map switching
led#1 brake switch
led#2 ignition cut active
led#3 AC clutch
led#4 AC switch
Old Nov 9, 2014 | 04:03 PM
PyroProblem's Avatar
This may be a dumb question but Does the fan speed have to be running?
Like normally the a.c. button won't light up unless the fan is turned on. Idk if it matters or not.
Old Nov 9, 2014 | 04:10 PM
on 0:34 seconds you can see blower speed 3 and blue light on AC switch
Old Nov 10, 2014 | 02:04 AM
Pullig's Avatar
if you have removed AC Im pretty sure you have to do a difficult work around... I looked into using ac switch but since I removed ac components mainly compressor you had to do a very tedious difficult wiring..
much easier to just find another input
Old Nov 10, 2014 | 12:36 PM
i did not remove the AC ...
do you use neptuneRTP ?
Old Nov 10, 2014 | 12:50 PM
Pullig's Avatar
No. I use ectune. But these inputs are the same across all platforms
Old Nov 10, 2014 | 12:52 PM
and your ectune log shows when your AC is activate ?
Old Nov 10, 2014 | 01:00 PM
Pullig's Avatar
No I don't have ac. So it can't complete the circuit. And send ground to b5 with that dash switch. However. It did before ac was removed.
Single-Cam
16
Feb 10, 2016 07:23 PM
StupidSlowRSX
Sep 3, 2007 02:28 PM
D
Aug 28, 2003 10:23 AM
