need help please
Old Oct 1, 2014 | 04:52 PM
tablecivic's Avatar
Default need help please
okay i figure i post here for future reasons. i will use this post as a reference. hopefully i get some help here. 1st part of this post is coil on plug.
i have series 1 aem ems (1000-0054) i know it's old. i sent the ems to aem, they did the hall mod, and set the jumpers. since this is a obd1 ecu i have use a step down harness. currently running a b-series engine. i need to know where to pin these wires in for the twin-fire module, and the epm. i have to ground two trigger wires. but what about the other 2 trigger wires ?. also does every wire need to goto the ecu ? such as grounds and power wires (with ignition power). i saw a post it says use b3 and b4 for the trigger wires but isn't that for automatics ?. thank you in advance for any help.
96 civic cx,b18c5,
Old Oct 7, 2014 | 08:01 PM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: need help please
seems like you'd get more help on the AEM forums.
also, general rule of thumb (and as a forum rule), threads with vague titles like "please help" are usually ignored.
Old Nov 3, 2014 | 09:12 PM
tablecivic's Avatar
ok well hopefully someone will look at this post lol ... how do you turn off the injectors in the software ?
Old Nov 4, 2014 | 10:11 AM
hpmx18's Avatar
if you download the install manual for the cop conversion from AEM it shows you step by step who to configure the correct option if your using EPM or T1 CAM TRIGGER etc... try checking that out or call AEM SUPPORT they offer great technical support
Old Nov 6, 2014 | 11:14 AM
accorse07's Avatar
https://honda-tech.com/attachment.ph...1&d=1415304760
File Type: pdf
boofunit
Aug 23, 2011 06:03 AM
BAM!
Engine Management and Tuning
Aug 31, 2008 08:20 PM
tuname420
Welding / Fabrication
Jan 1, 2006 04:17 PM
