p72 ecu problem
Old Jun 22, 2014 | 09:58 PM
louis96's Avatar
Default p72 ecu problem
My p72 board is damaged at the C27 capacitor.
When I got it chipped the guy said he fixed it but it threw the 0 cel and burnt the board more after I drove it.
I want to solder the capacitor to different points since the traces are damaged but I cant see which trace the + connected to.
If anyone has a diagram of the traces for a manual P72 jdm OBD1 ecu or a picture of the board underneath C27 that would be a big help.
Thanks
Louis
Old Jun 24, 2014 | 01:15 AM
louis96's Avatar
Default Re: p72 ecu problem
Someone must know which trace the + part of the capacitor shoud connect to?
Old Jun 29, 2014 | 04:11 PM
VegasInvasion's Avatar
I'm Huge In Japan
should be able to find a photo if you google the specific p72 that you have.
Old Jun 29, 2014 | 11:57 PM
louis96's Avatar
The problem is that the capacitor normally sits right against the board so you cant see which trace it connects to from a photo
Old Jul 4, 2014 | 11:12 AM
gen2integra2001's Avatar
what we would do is desolder the bad ccapacitor and clean the area with a q tip and alcohol. use a bright flashlight on the underside to trace the tracks.
Old Jul 7, 2014 | 02:01 AM
louis96's Avatar
The capacitor in the photo is not the original and i have actually cleaned it a bit. The track is completely burnt away at the point where it did connect so there is no way of seeing which one of the two strips it actually connected to.
I am thinking that bottom terminal should connect to the bottom right trace and not the bottom left trace.Can anyone confirm this?
Could i just solder it to that leg of the component on the same trace?
edwinie26
Apr 25, 2014 10:54 PM
MiNDTRiP03
Texas -OK -LA (Sales)
Sep 26, 2010 10:11 AM
heffnerp97
Jan 7, 2009 12:22 PM
